To be honest the only thing you have to lose is the cost of your materials. What you have to gain is a lot of satisfaction.
Make sure that your wig is well stuck on first though Andy!!Great jobI tip my hat to you
Lots to answer for. My drivers side was completely gone but my near side was fine too. Decided to change both though because I’m a bit of a nutter when it comes to symmetryCosts add up! Decided to replace my drivers side plinth as it was badly corroded. Went the X8R route, good quality, £86 with discount code. Noticed outer mirror cover was broken and 3 of the 4 screw fixing points were broken, so decided to replace with new, £31. Had cover and base repainted for £72 (very good job and perfect paint match). Just had to order new glass £49 as the original one won't resecure due to a broken tab (likely broken by me on removal, but don't recall). Total £238 - fortunately the near side is perfect! These mirror bases have a lot to answer for!![]()
it would’ve bugged me knowing it was differentThat had crossed my mind also!You can buy a whole Z3 for that ....
