Too cold to go and work in the garage today....sun’s out but the wind is freezing here on the south coast.
So I have stayed in the warm and taking my time over sorting out where I need to cut the armrest down.
( dont want anymore cockups !!!!
I will cut it with a 1mm cutting disc where I can and then a hacksaw if the disc cant reach.
I also have some sanding discs and flap discs, so should be able to shape it a bit at a time until I get the best fit.
I will start by removing the lower front part first, then cut off the two support lugs that stick out on the rear.
Once these parts are removed, it will leave a ‘box tower’ section. I can then check on what the final height needs to be and work back from that to get the final dimensions. But just taking off a bit at a time
Dont think I’ll bring the angle grinder indoors to cut it.....better do it outside tomorrow
)I will cut it with a 1mm cutting disc where I can and then a hacksaw if the disc cant reach.
