right.... I decided today was a non driveshaft nut banging day !
took the bin bags off the rust and was quite impressed
@DrWong ..doing job nicely !.. I've just setup a Screwfix account to ordered a cheapy angle grinder and some cup wheels... I'll add another layer later on...
then decided it was time to take the tank out.... I never knew there was a "formed" tank access hatch behind the driver's seat...
.just needs opening with a Stanley knife
annoyingly.. you can't get the 4th screw out without removing the drivers seat.... well... I couldn't
reading that
@IainP had trouble with his tank fixing bracket, so I broke as much rust off that I could with a hammer.... and gently rocked the strap up and down, tapping as I went.. eventually tapped it off the bracket... phew !!
Tank..... out... wallop !.... aaand I forgot it was half full.....
and the straps.... amazingly under the bolt heads, it was still shiny black !!
my little "homage! to
@Mazza
very clean under there with only a few spots of rust on seam edges that everyone has....
the tank neck got stuck.... so I rested the tank on the propshaft and managed to wiggle out the filler neck gaiter... and the vent pipe didn't break !!
only casualty was the bracket screw holding the brake and fuel pipes
and now I'm officially.... That One Neighbour
