With the guard...
Guitar studio mateStill nothing done....tried to torque one of the bolts this morning ......and pulled the muscle in my shoulder again.
I bloody hate being old !!!!!!
Did some easy stuff.....and just moved all the bits out to the garage....
If someone can just tell me where they all fit, then I might see some progress...
Two minor problems.....
Firstly, one of the O rings on the brake cable was damaged.....must have been me checking it out the other day......Luckily there is a company called O Rings Ltd in Chichester, so nipped over and they measured the good one and supplied me a bag of spares as samples. Brilliant.... a freebie.......or it would have been if I hadn’t gone into the town for a coffee and came home with a £500.00 Fender Stratocaster Guitar.
The other minor issue is that the conservatory is now tidy.......
...but also devoid of furniture which I got rid of......now it looks a bit empty
Better get some chairs!!!!![]()
Not sure why the previous post duplicated....
Today in the garage...
Fitted the brake shoes, Handbrake cables, brake pipes, new clips, anti roll bar , drop links , all the various brackets,
Nothing completely tightened up yet, just wanted to make sure everything fitted ok and I didnt have any bits left over. ( and I didn’t ....just lots of empty trays)
Next job I suppose will be get the rear discs and callipers fitted , the other hoses and sort the handbrake.
Then tighten everything ready to bleed the system.
Once the handbrake it reinstated, the propshaft nuts and the drive shaft to diff bolts can be torqued.
I am being a Diva today.....and any excuse to down tools
cant work with substandard parts
one of the original handbrake cable clips had broken so I ordered a new one....spot the difference
The white one is the new one.....but on the bag they call it a Pipe clip??? It is the right part though so I’ve ordered another one as the black one is showing signs of age !!!
Too late to start anything now as going to football in about 2 hours
Ian. That’s the trouble I don’t
I have loads of photos and RealOem exploded views plus everything’s in marked up trays. And I still have to work out which way up things go![]()
Don’t tell anyone but I noticed that the labels on the rear springs are now upside down. It doesn’t actually matter but it will probably worry me such that I will have to take them off and put the round the other way![]()
