My Z4................... My way.
Have you thought of extending the metal over the top of the filter as well Tony? The AFE version I have surrounds the filter, and the cover is removable to get access to the cone if needed.
Very impressed with your metal fabricating skills, nice tidy job all round :thumbsup:
I'm going to make a top mate just waiting for some more sheet alloy.
Now the scientific bit :thumbsup:;) I brought my lazer temp reader home from work today and when I backed the car into the garage I put the bonnet up straight away to help prevent heat soaking all over the engine bay. Here's what I found using this,
The oil filter housing was showing 88.8 deg.C.
The side of the heat shield nearest the Ramair showed 39.6 deg. C.
The Ramair body showed 33.4 deg. C.
The bracket from the oil filter housing showed 65.2 deg. C.
While the end of the mounting bobbin inside the shield showed only 31.8 deg. C.
As a control of sorts the car bodywork showed 26.8 deg. C.
So, I'm fairly happy that the air going into the induction will be kept cooler with the shield in place. Next thing is to look into scooping more cold air from the kidney grille area and test again, then fabricate a top and maybe close a gap or two as well and see what effect that has too.
Bozzy
Long Eaton.
The oil filter housing was showing 88.8 deg.C.View attachment 62597
The Ramair body showed 33.4 deg. C.View attachment 62599
Well that's some temperature difference, this can only be a good thing so your handy work with the heat shield does work :thumbsup:.
I've got one of those infra red thermometers,use it for finding cold spots on radiators, it's also excellent for winding up customer's cats when you wave the red dot about :ymdevil:;).
We'll that's some temperature difference, this can only be a good thing so your handy work with the heat shield does work :thumbsup:.
And people ! =)) Very useful for find which brake is getting hot(ter) and tracing the flow of a cooling system when you've got air locks etc.
Yep, I think it's worth continuing with Steve.:thumbsup:
Bozzy
Long Eaton.
Absolutely mate,but when you fashion a cold air scoop can you make sure it fits Atlanta blue Z3's as well :whistle:.
Hey, don't you start pal, I've got enough with me !!;)=))=))
Rha
Z4 coupe sport.
Shame that bracket from the engine side to the filter shield is a good conductor of heat, Anyway Tony that's a great bit of info and will help people decide wether it's worth closing the filter in. I'm also wondering what the temp is when actually driving along at say 40mph with the air circulating around the engine bay, got to be cooler surely. How much would that great piece of equipment you used cost.
All we need to do now is test some .org Zs with different setups( i.e. like Bozzy's ) to see how they compare. This is what modifying is all about, love it. Thanks Tony really interesting post.:thumbsup:
Roy:cool:
When I bought that kit it was £50 ish but they're much less expensive these days. I've had that one 15 years Roy.
Roy:cool:
I can insulate the stay bar by using an 8mm threaded bobbin at the filter housing Roy. I'll get one.
Reactions: Rha
Rha
Z4 coupe sport.
Just send me the details and I'll order one Tony. Great bit of kit to get someone like me interested in what it can tell you. Thought I knew a lot but just goes to show. Cheers mate.:thumbsup:
Roy.:happy:
Antm72
South Yorkshire
Roy.:happy:
I brought one to read the temp of the engine in an rc car. It wasn't expensive about £10 on eBay they work well.:thumbsup:
Reactions: Rha
A little job for tomorrow if all goes to plan, first nip to Marshall's Yard in Gainsborough to Car Phone Whatehouse for A 32gb memory card then get this fitted (rear view) before next weekend. So if you're behind me, behave ! ;)
ps. Bought a memory card at Carphone Wharehouse for £17.99 )Samsung) then went across to Wilko's and a 32gb class 10 card (Sandisk) was £12.:(
Rha
Z4 coupe sport.
Don't worry I'll get past whatever. =))=))=))
Arrived yesterday, works a treat not used it on the car yet.
Roy.;)
Let Sean go try your brakes and then you could test it !! ;)=))
So, dash cam fitted in the N/S roll hoop as last year. I'm struggling to find something to mount it on the outside of my Wind deflector panel which has enough adjustment to get it to film the road behind and not the sky ;) I followed this truck home tonight, foreign plates and boy he was not hanging around, 60 mph on a single carriage way A road? I was under the impression they were restricted to 50 on these roads and 60 on Dual carriage ways and Motorways? @Grumps.
View: https://www.youtube.com/watch?v=6FsJA4qa43M&feature=youtu.be
Rha
Z4 coupe sport.
I was under impression your restricted to 60mph on that bit of road, and if he was doing 60 you passed him at 75- then going on into the 80s IMO. That camera takes decent vid, but you really should be looking where your going not where your coming from.=))
Roy;)
SHHHHHHHHHHHHHHHHHHHHH. ;)
