My Z4................... My way.
That's why I have fitted them to mine. :)
Good write up Tony, I should have done one for mine.
A very professional job beginning to end.
Deserves some awards
Best Script
Best picture
Best Director
Best Producer
Best documentary
No end to the mans talents
While the waiting was going on, on the brake upgrade I turned my mind to induction. I found a nice Ramair system on eBay which was on a Black Friday " Make me an offer" deal so I did, would've been rude not to, and then this arrived.
Another satisfactory Saturday afternoon's work.
So there we were waiting for the brakes bits and then ............................................ , View attachment 50008
These new discs were treated to a couple of coats of paint to hopefully keep them looking like the day they were fitted.
Pads were ordered and asked for as the rear ones were a Christmas present, these are what I used for front and rear brakes.View attachment 50010
However they did look a little different by the time they were fitted.
View attachment 50015 View attachment 50016
The brakes discs and pads were eventually fitted along with some calliper decals. These are the finished articles. I was happy to see that the parking brake shoes were in good order.:)
View attachment 50018 View attachment 50019 View attachment 50021
That was almost it for the rear brakes, next the fronts.View attachment 50023 View attachment 50024 View attachment 50025 View attachment 50026 View attachment 50027 View attachment 50028 View attachment 50029 View attachment 50030
Really happy with the way these now look but most importantly by how they now work, much better brakes. :thumbsup:I guess that's it for now.
Did the ram air filter make any difference?
Not much doing this afternoon so perfect time for this.
A.C. not quite as icy as it should be.
Took out 650 grams about 100 down on what it should be. Autodata days 740g +/- 10. Sat in it then for while, looking for a soldering iron now!;)
You surely will Matt, unless I walk to walk to work and guess what the chances of that happening!=)) Oh, and thank you.:)
Took out 650 grams about 100 down on what it should be. Autodsta days 740g +/- 10. Sat it there for while, looking for a soldering iron now!;)
In yer garage R/H draw where I left it.:whistle:
So, here's a first for this thread. An item entered in this thread the day it happened. After fitting the cabin display part of my reversing sensors a while ago and finding I had a Saturday afternoon to myself I thought I should get the sensors fitted. First job was to measure and mark out the height and spacing on the rear bumper. For this I placed a strip of 2" masking tape across the rear bumper at the prescribed height from the floor.
Next to cut the holes ready to receive the sensors. Be careful of the cutting tool that is supplied as they are fffffffffffffffffffairly sharp !!
Remove the tape and then reverse car onto some 2" blocks of wood so I could get my trolley jacks under the jacking points and raise the car up a bit. I'd never had the rear bumper skin off a Z4 till today so it was a bit of a learning curve for me. The rear arch liner is attached to the bumper by 3 plastic stud at each side at the rear of the arches. Under the N/S is 1 8mm self tapping bolt near to the exhaust (but not the one which holds the exhaust heat shield) and at the O/S there are 4, all of which need to be removed. Then, the bumper just pulls outwards from the front edge at the wheel arch, it simply clips in to some clips all along the top past the rear lights.
Only things connecting it to the car are the two reg. plate lights which un plug easily. Put the bumper to one side now. Now I needed to find an entry point for the cables from the sensors and at the nearside the nice people at BMW had kindly left an unused grommet which was perfect for the job. This may well be where the factory fit parking sensor wiring passes through into the car.View attachment 52501 View attachment 52502 View attachment 52503 View attachment 52504
This where I decided to route the cables from the sensors and also where to mount the control unit as well, plus the "spare" cable.
While the bumper was off the exhaust tips looked in need of some TLC.
And then this,
View attachment 52506 View attachment 52507
Would've been rude not to ............................;)
After that I placed the sensors in the holes in the bumper, A at N/S Outer, B at N/S inner, C at O/S inner and D at O/S Outer, the reason for which will become clear soon. After fitting the sensors and routing the cables to the N/S I tidied them up by securing them to the centre two sensors with a couple of cable ties.
Having fed the cables through the grommet I lifted the bumper back up and fed the reg. plate light wiring through the light appertures, continuing to pull the sensor cables through into the car then finally clipped the bumper back into position and fitted the plastic studs and self tappers. Where the plastic studs fit.(3 on each side of the car)
The studs. You pull the centre "pin" out then the main part, refit in reverse order.
Next, the connections in the car boot. Found the power wire for the reversing lights and spliced a feed for the control box from that and made an earth for the ground cable. The 4 sensor were connected in reverse fashion A-D,B-C,C-B and D-A. The reason for this was that I had mounted the display under the dash upside down. Tidied up all the wiring and replaced the trims and covers in the boot. The finished article looks like this,
View attachment 52524 View attachment 52525
This is the display when you've reached the point where you don't want to go any further.;)
A very satisfying afternoons work all in all.
ps. If you haven't got one of these, do yourself a huge favour and get one :thumbsup: In conjunction with a 1/4" drive socket set such as this they're invaluable on a job like this.
Only just read this mate ,what a great write up :thumbsup:.
Must be a very handy thing to fitted ,my mate has them on his new van and he reverses frighteningly quickly relying on the sensors.
You can get caught out like that though Steve, Easy enough to fit mate.
ps. Our Gary bought me that set to be fitted on my Z3, so I've had them for a little while.;)
