Now the scientific bit
I brought my lazer temp reader home from work today and when I backed the car into the garage I put the bonnet up straight away to help prevent heat soaking all over the engine bay. Here's what I found using this,
The oil filter housing was showing 88.8 deg.C.
The side of the heat shield nearest the Ramair showed 39.6 deg. C.
The Ramair body showed 33.4 deg. C.
The bracket from the oil filter housing showed 65.2 deg. C.
While the end of the mounting bobbin inside the shield showed only 31.8 deg. C.
As a control of sorts the car bodywork showed 26.8 deg. C.
So, I'm fairly happy that the air going into the induction will be kept cooler with the shield in place. Next thing is to look into scooping more cold air from the kidney grille area and test again, then fabricate a top and maybe close a gap or two as well and see what effect that has too.
