there is a Z4 going cheap now...
Good, I need a daily so this can sit it the garage.there is a Z4 going cheap now...
MOT runs out on Friday, it failed on Tuesday. Excessive play in the drivers side ball joint and a leak from the power steering hose. I knew about the leak as we used some cheap clips which didn't quite do the job so Gookah will get them replaced and change the wishbone with new ball joints which should get it through. Nice easy fixes for him.
I’m amazed you let your dad that close. Mine takes far too long when he try n helps, he can’t see anything with his eyesight. It’s so funny watching him trying to find the right size spanner’sMOT retest today, all passed. Don't know whether to slap or thank @gookah!
Yes he did do some off the work, but the leak which he said was the clip (which I replaced) turned out to be the pipe and needed replacing. He luckily had a spare one that was made up and has done the job until I can find a replacement. The ball joint was fairly straight forward as we changed the whole wishbone that had 2 new ball joints plus a new lollipop and bush. But he was the one that sheared a bolt this time on the bottom of the droplink bracket It was an easy fix for now, new nut and bolt and I'll get a new bracket. My plan is to change all wishbones, trackrods, droplinks bushes etc in the winter. Just over £50 for a new wishbone with ball joints and a couple of wishbone bushes with the lollipops. It not often I praise him but he has come to the rescue again so thanks Dad!
Now got to finish rebuilding, almost there just some trim to put on which should be done for the weekend and then a good polish and wax ready for the shows.
call a doctor, I'm hallucinating now....thanks Dad!
Looking great. The door cards speakers: what paint did you use and what's the net/mesh, please? Were they easy to remove? And then replace?Panels back on
He sent me this last night, what has he done to it Looks like it's back in primer.
But not so bad after a bit of polishing.
Hopefully I'll get it back sometime next week.
You pair are so funny!!!call a doctor, I'm hallucinating now....
Careful Dave, you'll be buying him beer next...so thanks Dad!...
Oh dear I sense trouble brewing..I’m amazed you let your dad that close. Mine takes far too long when he try n helps, he can’t see anything with his eyesight. It’s so funny watching him trying to find the right size spanner’s
I have vernier fingers so I know the sizes required,I’m amazed you let your dad that close. Mine takes far too long when he try n helps, he can’t see anything with his eyesight. It’s so funny watching him trying to find the right size spanner’s
It could have been worse, if I had said it was the £240 pipe, and it then turned out to be the jubilee clip you would have been more annoyed.Don't know whether to slap or thank @gookah!
the leak which he said was the clip (which I replaced) turned out to be the pipe.
He doesn't even try finding the spanners, it's my job passing them to him. And once he's under the car he doesn't come out until the jobs finished, must be hard carrying that sort of weight around at his age.I’m amazed you let your dad that close. Mine takes far too long when he try n helps, he can’t see anything with his eyesight. It’s so funny watching him trying to find the right size spanner’s
Just shout your carer, probably not taken your meds again.call a doctor, I'm hallucinating now....
Yeah right, I did give him a 50p jubilee clip. Christmas has come early for him.Careful Dave, you'll be buying him beer next
Must have been all that weight behind it when you were tightening it with your footYes I sheared a bolt on his rust bucket, but I was only able to do that by using a correctly sized socket, nuff said
Do you not think I would have gone with the cheaper option first. Muppet.It could have been worse, if I had said it was the £240 pipe, and it then turned out to be the jubilee clip you would have been more annoyed.
Doorcards need to come off, speakers removed and the cover is held in with one screw if I remember then it slides out. You then need to prise back the tabs that hold the grill in so it can be removed and painted. I just used cheap satin black paint from Eurocarparts. And some weed control material that’s sits between the grill and holder. Then refitting is the reverse.Looking great. The door cards speakers: what paint did you use and what's the net/mesh, please? Were they easy to remove? And then replace?
