Time for a mini-update. I've been bouncing around the car knocking out what I can. I've been trying to avoid doing any fiberglass or body filler work while it's so cold out. Let's get to it...
More headlight work! Since I bonded the bezel to the body, it was time to get rid of the original bezel inside the headlight bucket. I needed to clean it up in there. Created a LOT of dust in the process. I was still wearing all of my PPE, but I'm really glad I installed a ceiling mounted air filter. A HUGE difference. I took before and after pictures but you can't really see it.
This bezel has been obliterated. Now it's just the bonded bezel...
As you can see above, I've also started gluing in hardware for the clear lenses to mount to. I used longer bolts here in case some of the glue got into the threads. I cleaned off any glue that did get on the bolts. Once the glue set a bit, I took the bolts out and called it good!
Spent some serious time on the rear of the car trying to get it to fit right. What a juggling act. I decided to try and reduce variables by removing the trunk. I put a jack behind the car to lift it a bit which helped the door jams to straighten out. Then a game of "how many washers can I stuff here and there for this to look right".
There are also 3 more bolts on each side holding the rear on right where the trunk hinges are. I think I got the door jams decent:
The gap is bigger than I would like, but there is no play left in the body to move it forward anymore. I'm thinking about welding some material onto the doors to extend them and fill the gap, but it may not be worth it. The lesson here is "good enough for me" and tell anybody that critiques it to go pound sand.
Now that the rear is pretty close I can finally tackle the fuel filler! I had to re-cut the fuel hole (4 tries later...) and got them lined up enough for flex piping. Here's what I'm working with:
OEM fuel filler on the left with a pipe welded on (or at least will be), flex hose and modified motorcycle fuel filler. Check it out...not bad.
Terrible picture, but I was excited to see this part show real progress. When the weather gets nicer I'll fille the hole and bond the filler to the body.
Another thing I started looking at was the very rear of the car. If I modify the trunk hinges (which I might have to do anyway) I might be able to get the trunk flush mounted to the rear rather than having a lip. Here, let me show you...
Kind of nice looking. Especially if it didn't require my knee to hold it there.
Last thing was to start playing with the rear wheel wells. I stuffed the OEM ones in there and started marking where I'll trim them down to get a nice fit.
Small steps here and there but progress is progress.
