It's been a minute but I haven't been idle. Life finds a way (to get in the way).
Alright! Lets get back to it.
I stuck with the new light design and finished them off. Basically they are an 80mm aftermarket halo (will act as day time running lights) with a center 2" aftermarket light for motorcycles. I CNC'd an acrylic ring and spray tinted them to make the lights look like one solid unit. The tolerances are nice and tight so everything fits together really well.
For the fronts the halo is white and all of the halos in the rear are red. The center lights can turn amber or white on the light shown. This is usefull for turn signals in the front and rear. The white will act as my reverse lights. The center light is red for the brake lights. (Two stages, fairly bright for running lights, then really bright for when I brake.)
Now that I don't need a reverse light on my license plate light I can spring for a MUCH cheaper version of the lucas light. Like this guy:
There were a few things to address on this. First off, in order to put mounting holes through the back of the housing I'd have to gut the inside.
The bonus of doing this is upgrading to a nice LED bulb with a fixture from a Harley Davidson. Who knew Harley's would be so beneficial to this build. I then punched out holes through the back and put in threaded couplers. The other issue is the color! I ordered some brushed metal looking vinyl wrap. Lets see how that looks...
I'm happy with this. Lets move on.
Hopping around a lot here. I got new seats in!
Woop! Very happy with these. They haven't seen sun yet so they should tighten up a bit more with time, but I think they look great.
My buddy came through with some nice speakers for me. I'm going to update the tweeters and mids in the doors which will require a bit of work to get them to mount right. I'll also need to respray the metal speaker grills. They are pretty beat up. The footwell speakers were 5 1/4", somehow I have a set of 6 1/2" that nearly drop right in. I guess the flange on the OEM speakers were pretty wide?
I also decided to dump the sub-woofer in the center. Anybody want to buy a subwoofer and enclosure? I saw in other trim models the car comes with a lockable storage bin. I'll be hunting around to swap that out. It will be much more functional that way.
More pictures Matt!! OK ok.
Next on the list was a fuel filler. I found this...from a motorcycle. I really like it because it's small, clean and simple. I do like the classic flip top fuel fillers, but in my opinion it's just a required functional component of the car and I don't want to draw attention, so this is what I found:
I'm not 100% sure this will work yet, but we'll get there.
Time for wiring! I got a set of waterproof connectors and picked up a pack of soldersticks (these things are cool and make a nice solid connection requiring a heat gun.)
In the above picture, the license plate is held on with painters tape. I just needed a visual. I'm really happy with the lights. I'm thinking of trying to recess the license plate light more. It sticks out pretty far. Maybe another 3/4" in? Debating on this..
Now it's time to start aligning these headlight buckets. I wish they came with a flange so it would have more of a connection point when it comes time to glue it to the body. I'm going to use a polyester resin, and with the suggestion from a friend, a strip of fiberglass around the edge to give it a bit more structure.
You can also see the front halo/turn signals are mounted here as well. Oh, I also got my grill in...
You can see this painted and in place in the above picture. I think I'll fill the outside so it merges with the rest of the body for a nice smooth look. Here's a before and after look.
The headlights will be projectors. Also with a white halo that will turn amber with the turn signals.
I cannot wait to see these in the car.
Decided to play around and pretend it was done. Check out this view! I was most definitely not making engine noises here. Also bonus of the side view mirros actually being effective..
Thank you! Also I'd welcome any suggestions on the build if you are watching and shaking your head.
