You could bring them with you when you bring the beam up. I have a big boy nugga nugga gun. There’s also a tab locked in the end that you’ll need to remove first.Bit disappointing today as I didn’t get as far as I had hoped.
I started by spraying all the nuts and bolts that need to be removed.
Then proceeded to undo everything to get the beam out of the way.
Using my impact gun, the diff bolts undid easily, as did the outer trailing arm bolts. Couldnt get the gun on the inner ones so use breaker bar with a push on ratchet attachment. ( bought it after seeing one a few months ago on here by @t-tony )
All good and beam freed off and put it out of the way.
Then, removed the ABS sensors and wear indicator wiring.
Now it started to go wrong...
Went to remove the 12 Torx bolts from the driveshafts to diff and had no way of holding the axle still
What I should have done was loosened them when I loosened off the 4 propshaft to diff bolts earlier in the proceedings
Eventually, after thinking about it, I put a wheel nut back on and held it still using a long breaker bar with my foot on it. Used a smaller breaker bar on the torx bolts and it workedHappy again!!!
Celebrated this achievement with a cup of tea.....
Now ...in my mind...I thought...that the driveshafts just pulled out of the hubs.....But mine wouldn’t
I did try pulling, but to no avail. And I remembered when @ZedHead did his refurb, one of his was also stuck.
So thinking that there might be something mentioned in my Bentleys manual....went to have a look.
OH F***, theres a bloody nut on the end that is torqued to 200nm, and it recommends that this is undone while the car is on the ground.......BIT BLOODY LATE FOR THAT
AND absolutely no blame on me for not reading the book first !!!
Now I have to find a way to get it undone ......suggestions on a postcard to Dummy of BOGNOR !!!!
At this stage I could have removed the calipers, discs, brake shoes, pipework etc .....but decided that I needed a break while I work out a cunning plan to get that nut off and release the drive shafts from the hubs.![]()
), and has thrown up a few queries that have confused me a bit. So any explanations gratefully received.
....does that mean you torque on the bolt head and hold the nut.
Likewise,Looks like a surgeons operating room mate. Re the suspension arms, I was taught that you should hold the bolt and tighten the nut onto it.
A shiny car is a happy car. Faster too as less dragThanks Tony,
On the second point, And I am being really dense here....does that mean you torque on the bolt head and hold the nut.
On the third point, I do have a set of impact sockets that goes from 10 - 32 mm so have a socket that will fit the axle bolt. However , I’ve chickened out of trying to undo it at the moment,
Todays effort
Too old to work on the floor.
First one took a while as taking pictures of everything so hopefully I can put it all back together
Second one was a lot quicker.
Amassing loads of little bits.....yet to be cleaned .......but all labelled
Just as well I was replacing these anyway as the inner faces were badly scored.
Now on to the boring bit. ( unless you are @andyglym ) Cleaning all the parts I’ve taken off so far...![]()
I had a feeling you were on about those bolts, Just torque them as you would normally. They don't need alot of tighty@t-tony and @Lee ,
I understand what you are saying that the torque should always be applied to the nut ( which is what I’ve always thought it should be) , but the nuts are fixed on the outside of the pairs of beam brackets. ( ie one by the main bush and one by the centre tunnel part of the beam on each side ) and in that position I cant get a socket on to them to be able to use a torque wrench.
Or am I really being so stupid that I shouldn't be allowed to have a zed in the first place......![]()
[/QUOTE]
