Carried on spraying all the various nuts and bolts with penetrating fluid....the fumes got so bad in the garage had to open the door
But I did have a tidy up and put all the bigger bits ( wheels etc ) out of the way in the shed.
Once the air had cleared I carried on..... very carefully removed the 6 nuts that held the heat shield (10mm AF)
These nuts have integral washers about 1in dia,
Happily they all undid without snapping off the stud. ( so good start to the days’ proceedings)
It was a bit fiddly to get out only because the front end of the exhaust is still in place.
Next the brake cables......slid the gaiter out of the way and got to the locking nuts fairly easily 9mmAF and 12mmAF
Only took the picture so I would have some idea of where they should be when its all reassembled.
( To that end I been like paparazzi photographer and have taken loads doing all this)
Having removed the heat shield I could now see the cable ducts which were stuck, but a bit of fluid , a tap with a spanner and wiggling with a pair of pliers out they came
Need new cables as one had the outer sheath broken in two places.
Easy bit next, disconnected the electrical cables, diff cable, brake wear pad, and the two ABS cables.
At this point after numerous soakings and cleaning out the dreaded M8 captive hex bolts, I thought I would try to break/loosen all of the remaining nut and bolts.
Two brake pipe unions ( 11mm brake spanner ) ok
Two large Beam bolts. (22mmAF socket with breaker bar)
Then ran into a bit of a problem as the 1/2in drive H6 Hex socket that I have would only fit the front captive nuts on each side. The rear ones are close to a flange in the plate and my socket would not seat correctly.
You will have seen in the earlier post that @Lee came to my rescue again.
So been out an bought a 3/8 drive
Ready for tomorrow now......and will follow the instructions as per @Synclare , and hopefully they will undo without any problems.
Just realised writing this, that I forgot to have a go at loosening the diff bolt.........
So all being well tomorrow.......should have it all on the floor.
( and for those that frequent the ZedSheds’, for you, it must be like watching it in super slow motion...
