Really Useful tips @roadvoyager1 .
To drop it in one lump, I have thought of making a wooden support frame and using the two trolley jacks that I have.....and let gravity take over .
If it works ( and I don’t get trapped underneath
) I could use it to lift it all back into position.
(If it works really well, then it could be available for anyone else taking on this job on their own.)
Luckily I have a stainless steel exhaust system that has a spring clamp so that I will be able to remove the cat and rear box only.
There are a couple of local engineering companies, from my days as a Purchasing Manager, that I could call on, in the event of a problem. One of which has the facilities to make tank straps, should mine need replacing.
