Had some spare time one snowy day last week and got the new bushes pressed into the housings.
View attachment 75237 View attachment 75238
And so today, when I managed to make a little time this happened.
View attachment 75236 View attachment 75239 View attachment 75235
Has certainly sharpened up the steering but the downer is that I couldn't get it tracked because the legs won't go between the rear tyres and arches. Will have to wait until I get new tyres on my 108s and can refit them.
Tramlining virtually non-existent now
. I found a good way to remove the old bushes too. I removed the 2 bolts which hold the mounting to the chassis rail, pulled the arm down and wedged a block pf wood between the arn and chassis. Then screw the 2 bolts back into their holes al the way by hand, you can then use a bar located on the first bolt head to lever the bush half way off the arm, then move the bar to the second bolts head to lever it all the way off. Remove the bolts, lightly lubricate the poly bush and after making sure it's aligned correctly push it on to the arm. Then bolt the mounting to the chassis ensuring the dowels locate into the housings.
