My Z4................... My way.
Redline
Nuneaton
E89 20i msport
Couple of little jobs this week. Front splitter removed, the snow and ice did that for me in reality, but a little kiss on a kerb near Leicester last Friday finished the job.
Last Sunday one of the Osram Nightbreaker bulbs I fitted 2 1/2 years ago failed so I ordered these, the upgraded ones £18.50. fitted yesterday.
Haven't had a chance to try them out in the dark yet but if the new ones are a genuine improvement I'll be very happy.
Lastly, job's a good un!! Guess what I did today.
And Yes, with flying colours. Apart from advising a front A/roll bar drop link boot. A job for another day and best of all it was free !
You get 100% discount on MoT?
Cor!!! :)
Nice to see another pass, but then wouldn’t expect anything else :thumbsup:
You're getting too much like HT Pete.=))=))
Bozzy
Long Eaton.
Congrats on the mot pass mate, I guess you're probably stricter on your own car as well.
Real shame about the front bumper :meh:, are you going to repair it yourself ?.
I'd be interested to see how the night breakers compare to the standard ones.
Yes mate, that's my plan, although some other ideas cooking on the back burner. Something(s) ordered but not be here for a few weeks.
Worst things is a plastic "box" type of section under the bumper took a hit and although available (Sopers could've got me one for this afternoon and I only rang mid morning) it'll cost £150 :(. So I'm scouring the breakers for the time being but at least I know I can still get the genuine new part if all else fails.
I'll get out in the dark hopefully tomorrow evening Steve to find out. Like I said if they're better than the original ones I fitted I'll be happy mate. I'll repair the bumper easily enough, and as Dave said the front centre section is almost a separate piece which was the only piece of good luck I got:thumbsup:
ps. To be honest I test every car as though it's my own.:)
Bozzy
Long Eaton.
Sounds a lot for what it is, I can see why cars can be written off by insurers for a minor bump when parts like that cost so much.
Fingers crossed you find a good used one at a good price.
I'm hoping so mate. I went to work armed with a list of 7 eBay breaker's phone numbers but never had a chance to do any calling. It's just got to be lucky to catch someone with a fresh car with little or no front end damage before they start "breaking"
Tony
Thanks for posting that mate, they certainly cast a good light pattern. Better than the standard bulbs then ?.
Better than the old Osram Nightbreaker definitely, and they were a big improvement on standard 55W bulbs Steve.
Bozzy
Long Eaton.
Not sure what I've got fitted, but they seem ok. Although I don't do much night time driving to be fair.
I guess I should take a bulb out and have a look what's in there.
What with mine being my daily Steve, good lights are a must have for me.:)
Bozzy
Long Eaton.
Absolutely mate, it's different for you as you said especially if you have unlit roads on your route to work.
When Shirl and Gary were over in Florida I took my usual few days off work with the intention of doing a couple of jobs on my car. First was fitting some LEDs to the outer door handles and some BMW logo puddle lights in the bottom of the door cards. I had a small issue with this due to unforeseen circumstances and what with a whole load of snow and Shirl coming back poorly from Florida I haven't really had time to try to sort it out until today. I didn't take any pictures during the fitting but a basic run down is you extend the foot well courtesy light wiring into the door through the trunking at the "A" pillar then route the wire up to the door handle where you drill a 6mm. hole and glue in a 6mm. LED (pre wired to a small 2-pin plug and socket) and connect to the extended wire. At the bottom of the door you Tee in a spur and add a 2-pin plug which plugs directly onto the puddle light. Holes cut into door card by measuring the size rectangle required then drill a 3mm. hole in each corner and cut the sides out with a Dremmel type of tool. Something like this.
The LED in the door handle looks like this in the daylight.
This is what you see when it's dark.
Pleased with the look , pictures really don't do it justice.
I bought one but not fitted it . . . . . . Yet.
