I thought raise/lower was good up to 20 mph ? I think its actually 22/23mph, but 20mph is reliable. But glad you're all sorted . . .
I think, having tried it I could up the speed to No.3 Alex. That would be nearer to the speed my Z3 worked at.
Your hand luggage for the return trip is getting a bit full already !New tool for the Shed.
Not a full blown "pressure" washer but a power cleaner, runs off Ryobi 18v battery, giving 320 psi, fed buy a 2ltr bottle, your garden hose, or, it will draw from a bucket through the 20ft hose supplied.
I have a dreadful xperience with plasti-dip.Much tidier but If that film lifts off Tony you could try red plastidip spray that you can peel off when you want it back to black.
You can get ointment for that these days . . .There are red dots on them Ken.
Those butties are worth the trip out all on their own !
Is that this weekend ? Is that short notice for some maybe ? But yes, no problem, anytime . . .
Good alignmentYesterday evening saw me and Shirl in the oil burner visiting @Simon ireland to purchase a set of refurbed alloys complete with a set of new Budget tyres. I discovered 2 cracks in my N/S/R wheel a few weeks ago and 1 new rim from BMW would've been over £700 inc. Vat. so this set of wheels & tyres was, to me, a no brainer.
So this morning armed with a product I bought from a Target store,
I set about applying 2 coats over the "new" wheels, insides and out.
View attachment 237983View attachment 237985View attachment 237987View attachment 237989
They came with brand new centre caps which just needed a colour change.
View attachment 237991View attachment 237993
Three laps of insulting tape makes them a better fit and less easy to remove (I discovered this many years ago when I had my Z3),
This is the 1st of the rear wheels done ready for fitting. @andyglym please note correct alignment of valves, centre caps and ///M badges. and "go faster" valve caps!
And the 1st of the front ones also ready for fitting.
And the full set.
After fitting, where I fitted a pair of 20mm spacers on the rear and switched the previously fitted 12mm ones from the rear to the fronts.
View attachment 238001View attachment 238003View attachment 238005View attachment 238007
Later, out in the rain. I'm not 100% sure about the wheel bolt caps yet (I wasn't on the previous wheels if I'm honest) but they need something as the front and rear extended bolts have different heads. If not Red then maybe Gloss Black or Bright Silver/Chrome?
View attachment 238009View attachment 238011View attachment 238013View attachment 238015View attachment 238017View attachment 238019
Really pleased with the outcome.
ps. I have a couple of other things in the pipeline too.
