Today I got chance to change the bushes on the seats, first the passenger side.
Unit out and ready for the new bushes
Side by side from the same seat
Old ones are not actually that bad
It's not that often the passenger seat gets used, so they weren't that bad. There was some movement in the drivers seat but not a lot, you can see the originals below. They did have quite a bit of play when I took them out and they fell straight out of the housing so needed replacing sooner than later.
All back in and the threads were greased up nicely. I left the drivers seat for last as I wanted to fix a problem thats being bugging me for a while, one that wouldn't be quick.
The belt holder was loose at the bottom as it had come off the starlock washer. These were originally coupe seats and had no belt guides so I installed new ones not long after I got them. To get to it meant stripping the leather up the seat, not too hard just time consuming.
All for this little bugger
Managed to secure it back on and put the leather all back in place. I did tape up the drivers side bolster as it's gone a bit saggy, plus stuffed a couple of microfibres in there to fill it out a bit
Ideally this side needs new foam but that's too much work and money for now.
Back in place, much better.
Will see how the new bushes perform once it's all back together and were allowed out.
