Daily driver, goes out in all sortsWhat’s the Zed doing out in the snow?![]()
Well I got up the drive fine today and cleared a bit of snow with the splitter coming out of itMe too Dave, not looking forwards to using my front splitter as a snow plough though mate.![]()
Most of the roads aren't too bad now but all the slush and crap has gathered in the middle and is the perfect height for my splitter and bumper to plough straight through it. Think I'll leave the zed in the garage for a few days. Have to say though the tyres were great today, I have to go round and up a steep hill to get out of the estate and it was a breeze earlier.As far as figure skating scoregoes: 2/10Well I got up the drive fine today and cleared a bit of snow with the splitter coming out of itMost of the roads aren't too bad now but all the slush and crap has gathered in the middle and is the perfect height for my splitter and bumper to plough straight through it. Think I'll leave the zed in the garage for a few days. Have to say though the tyres were great today, I have to go round and up a steep hill to get out of the estate and it was a breeze earlier.
I can't get any speed at all off the drive I have to crawl up over a ridge then down onto the road as it catches the front splitter and scrapes like mad under the car. It's worse now with the hardtop on, even though it doesn't weigh much it catches even more. Plus there's a muppet who parks their car on the road opposite the exit making it tight.As far as figure skating scoregoes: 2/10
That exit was way too civilised and controlled.
Ditch these silly winter tyres and get a full oppo drift out the drive at 3mph for an 8/10
I use a couple of wooden planks (3/4" thick) to run the car over a slight ridge and into my garage - would this solution help?I can't get any speed at all off the drive I have to crawl up over a ridge then down onto the road as it catches the front splitter and scrapes like mad under the car. It's worse now with the hardtop on, even though it doesn't weigh much it catches even more. Plus there's a muppet who parks their car on the road opposite the exit making it tight.
I will try harder next time though![]()
Probably but they need to go from the ridge at top of the drive over the pavement and onto the road, the driveway is also access to 4 other garages for the neighbours. I'd have to keep them in the car and put them down every timeI use a couple of wooden planks (3/4" thick) to run the car over a slight ridge and into my garage - would this solution help?
And ditch the HT,You can try higher tyre pressures. When mine are low it will scrape a particular speed hump, pumped up full and it doesn’t, can’t be much difference but just a little to help.
Or lose weight over winter to compensate for the HT! (Less food and lose spare wheel, run low fuel etc!)
I’d normally agree but it’s looks particularly good on this car. On standard cars I think they don’t look right but with finished Car like this it’s look great.And ditch the HT,
Not talking about the thing on the car Dino.I’d normally agree but it’s looks particularly good on this car. On standard cars I think they don’t look right but with finished Car like this it’s look great.
And all those years you made me believe, I always knew Santa wasn't real, if he was he would get me what I wished for.keep hoping.....
I have found it catches more with the 17's than the 18's both with hardtop on, even with the same pressures and they are the same diameter which is weird. Spare wheel is gone, must be my weight!You can try higher tyre pressures. When mine are low it will scrape a particular speed hump, pumped up full and it doesn’t, can’t be much difference but just a little to help.
I find the same thing between 17 and 18. I think maybe tyre brand impacts it but the car is definitely lower on 17’s despite the online calculation saying it’s yhe same.I have found it catches more with the 17's than the 18's both with hardtop on, even with the same pressures and they are the same diameter which is weird. Spare wheel is gone, must be my weight!
Raise your bum from the seat to see if it makes any difference driving over the ridge.And all those years you made me believe, I always knew Santa wasn't real, if he was he would get me what I wished for.
