I’m being held hostage by an MX5 forum
It’s like he’s got a life or something!He's been a nightmare this year, we've only seen him twice all year![]()
Thanks to @AntStark for connector with wire attached
No excuses aka distractions now the generator is fixed! Let’s see the 2.8 finished now - PLEASEStarted with all good intentions this morning , and found where the roof microswitch goes, so….after 30 minutes locating the two torx screws, reattached it , and after taking down one of the net curtains to use the curtain wire as a pull through, got the wire installed down through the frame.
Next was to solder and sleeve the wire to the connector lead so it’s ready to plug in. But will need to work out how it routed so I don’t make it too short….Thanks to @AntStark for connector with wire attached
At this point the postman arrived with the parts needed to repair my generator …. so decided to rebuild that instead .
Which I can say is now all done and working.
I might see if the roof lines up by doing a dummy run on bolting it up before actually putting the sealant in ….![]()
, It was fixed with the same butyl so with a bit of persuasion managed to realign it and tightened up the 4 bolts to hold it in place.
Thats not bad @ 30p ea…. But I wanted them today so paid the 65p
…….more clips to break!!!!!!
