Bognor Lean-to Project
Mazzal
53 pages of total waffle - you gullible fools he has been getting somebody in to do all the work - while he just sits and watches and taking photos - anyway Malc when are you going to deliver it to us 😂- joking aside, well done Bruv - I’m sure there is another Bognor Lean-to project around the corner - The Sequel 😂😂
Mazza
Bognor Regis
Z3 1.9 M44 Roadster Z3 2.8 Roadster
Well ok …. Just one more little job………
The post arrived with two strips of blue leds… should be really quick…so removed the glove box and the lower trims from each side
9
Self adhesive leds stuck on the lower trims… plus a couple of holes for the wiring
pulled the wire through under the heater and soldered it to the led strip. ( they came with 30cm of wire which I desoldered as they needed to be longer.)
The two large holes are where the fixing clips that hold it up go . The hole that I drilled is just below the left hand end.
Then I just needed to connect the positive feed and the negative earth
For the Earth just crimped a ring terminal and found a convenient point.
The live is a brown and black wire that goes from terminal 4 of the plug behind the glovebox and goes to the interior light,
Only problem …….I couldn’t remember which plug it was :whistle: ……..so removed the glove box on the 1.9 to find out
its the black connector on the left……so like before ( as below) unclipped the black loom tape exposed the wire and used a connection clip then used cable ties to hold it back together again.
Then just a case reassembling both cars.
And all that effort just so when you open the car door at night it looks like this ….
Thats it now …Project Complete …… ( other than maintenance stuff :whistle::whistle::arghh::arghh::arghh:)
Mazza
Bognor Regis
@KASPar You mean like this ….. in the 1.9. =)) =)) =))
