I think it's a pro flow. Supplied and fitted by custom pipes in Doncaster UK.what brand on the catback Bozzy
Yes thats mine, Tonys looks the sameI believe someone else had a pic of RamAir earlier
This is my Ramair on my E85 Z4 3.0i. On this car you can mount it directly at the point of the original air filter intake through the front panel.I believe someone else had a pic of RamAir earlier
.wow!!! that sounds wickedThis is my Ramair on my E85 Z4 3.0i. On this car you can mount it directly at the point of the original air filter intake through the front panel.
Listen in at 1.52 seconds for the induction noise, that is all induction as I'm running a standard Z4 exhaust, ...... for now.
View: https://www.youtube.com/watch?v=QjS5-Uv0PoM
No mate, piece of aluminium donated by T-Tony. Made a pattern out of cardboard cut the aluminium to pattern drilled a big hole for the induction pipe and fastened to the existing air box bracket and inner wing. Finished off with a £2 piece of trim from E Bay.did that shield come with it Paul
Do you have the link for the knock on mate, I can only find 5m lengths of the small stuffNo mate, piece of aluminium donated by T-Tony. Made a pattern out of cardboard cut the aluminium to pattern drilled a big hole for the induction pipe and fastened to the existing air box bracket and inner wing. Finished off with a £2 piece of trim from E Bay.
It was quite easy really, just as well my fabrication skills are very basic.
Looks great TonyI started making a heat shield but still need to make a lid for it.
View attachment 95889 View attachment 95890 View attachment 95891 View attachment 95892
Bear in mind that both Paul's and mine are Z4s and that they're fairly different under the bonnet from a Z3.
This looks similar SeanDo you have the link for the knock on mate, I can only find 5m lengths of the small stuff
He's not bad is he! Imagine how good he'll be when he's finished his apprenticeshipThat's not an update! It's just showing off the amazing work you've done with more pictures
Keep 'em coming![]()
