i used a stanley knife, just be care full you dont do yourself an injury, i shaved along the top curved edge first to make the plastic thinner where i was cutting, i cut with the blade horizontal so not to touch the circuit board underneath.
ok quick update - plugged inpa in this morning and like
@Antm72 i had a break switch error. plugged repaired module in attached to the valves and pump my ebay replacement came with, same error code as it originally had (suppose it would be as its stored in the module itself). creared code and i did not come back huray. couldn't go for a drive and test it as it was just hanging there, so i plugged the replacement back in again. cleared brake switch code then quick drive around, code back again. so back into inpa and cleared code, powered down inpa and opened NSC expert, then proceeded to code my replacement module with the factory code stored in EWL module into ASCMK20 module, took about 2 min, brake switch code gone huray, quick drive around again and so far NO CODE AND NO LIGHTS
now all i need is a gravel road somewhere to test the ABS and ASC.
nsc expert - load expert profile, then f1 - select chassis - e36, then back button, then process ecu, this gives a list of ecu's select ASCMK20 and execute job, done.
