Feathering in is the tedious bit. Fortunately I've done training in dry lining (random diy decision) and do quite a bit of that which is definitely helping.
Looks like its been done at a body shop mate, great work.T'other side nearly there now too. Done much quicker than the driver's side as I'd found the best tools for the job by then.
Appreciate that thanks @Sean dLooks like its been done at a body shop mate, great work.![]()
Don't know but happy to check if I remember when I extract the donor engine as I will be replacing the CCV system.I know I should have asked before you got so involved with the underbonnet stuff, but I've been trying to sort out a small problem on my own 2.2 (just one of many). There should be a picture attached hereabouts, showing the CCVV, I've changed it in the past hoping to cure the oil drinking problem but no luck there. The picture shows a pipe attached to the valve(no.6) but I can't find it anywhere, and no idea where it goes to. Any chance you could have a look to see where it goes?
It's damn difficult looking under there, as no doubt many of us have found, would love to know where it goes.
Thanks, did wonder about that. I think I'm best being happy with what I've got though.If you really want a satin finish you could always give it a light flat and get rid of any bad stuff such as runs and bits and then apply a light coat of satin lacquer, that will tone it down.
Use a tack rag before applying the lacquer.
