Notice the subtle thread hijack? Thank you for that, it had me wondering for a long time where the port was supposed to be connected to. May get hold of some hose and try joining the two ports together, can't make things worse, and may improve the oil-guzzling. Strange that RealOEM show it, but hey.Iirc
- The M52TU engines use the small 3.5 mm tube from the CCV separator middle connection (6 on the E39 picture in the above post) to the rear of the inlet manifold 3.5 mm port. (see below photo of a M54 inlet manifold, bungs fitted but this is where the 3.5 mm hose connects on the M52TU engine))
- The M54 engines do not use the 3.5 mm hose and have a bung on both the separator and inlet manifold (see below photo of a M54 CCV separator with bung fitted)
It's not actually out yet. But yes, I started to clean it in the donor vehicle yesterday. It will get a thorough clean once it's out and (H&S look away) while it's hanging in the air waiting to be installed. Unfortunately I didn't have my fan spanner handy otherwise that would have been taken off to give better access.Will look good with the motor back in Rob, have you given it the once over while its out?
Interestingly enough that bung was perished on my donor engine. I just got a new one from the dealer. I think it was about £1.50.Iirc
I reckon for every hour I spend working on the car I can typically spend an hour researching what I'm doing on here/rest of the internet. Sometimes it can be more like a ratio of 1:4-5 hours. So there will be plenty of poolside reading up on the iPadGood work and an interesting read. Are you taking any small components on holiday with you to fettle by the pool?
You'll probably get some better weather out there for spraying, shame to waste it laying around!
Cheers,
Jonno
