Small correction and expansion on my earlier message about the perished vacuum connector.
It was connected to the fuel supply as I thought (well the pressure regulator) but it's to the black hard plastic pipe as it comes up off the chassis and not the blue one which it's tied to. As it comes off the chassis it goes into a flexible section which had literally started to crumble away. At the other end this goes into the lower connection on the F-piece which taps into the air intake boot beyond the MAF sensor.
I checked a 3rd 2.2 and this is also afflicted. So 3 out of 3 cars affected. An important check for anyone.
A few photos to make sure we all know where I'm referring to. This is the nasty crumbling section - much worse up close than it looks here.
Here's the lower end going into the black hard plastic chassis line.
And the other end where it goes into the F-Connector (lower hose).
