The front end is pretty much complete now. It's looking like a Z3 again!
Rubber bonnet bump stops cleaned up and screwed back in. New radiator clips and black top trim cleaned up.
New headlamp adjusting mounts fitted.
Wiring harness clipped up across whole of front and earthing points cleaned up and remade. Front panel bolts will get a blast of colour when I'm happy everything is aligned properly.
Power steering cooling loop bolted up with new rubbers and nuts.
Little bit of a wrestle around the nearside headlamp to get the wiring harness positioned.
Headlamps on. Loads of care taken to position the headlamps correctly so as not to strain the mounting tabs and to get as close to right first time as possible with the bumper on. The top plastic mount screws can be counter-held with a 19mm spanner. The bottom ones need an 8mm socket on the underside.
And they work!
Bumper shocks bolted up. Bumper placed on loosely. Needs mounting brackets and wheel arch liners refitted. Then probably some adjustment on the headlamp positioning in the aperture.
I want to get it MOT'd next week. There's a little more work than I'd like to reach that point. The main refitting jobs are rear wings & boot lid, roll hoops, seats and bonnet release.
And they work!
