Can’t believe I didn’t update this. LSD is in and it’s transformed the car in the corners. With two track days to get used to it 100% very good value for money.
Old unit vs LSD unit
transferring over the crown gear
new seals and bearings she’s ready to refit.
was a week till I drove it in anger.
next up the starter motor died, it screamed so loud when it gave up I thought something was in the engine bay. So a Lucus replacement bought from Euros that same afternoon. Luckily with the black top N52 engine you can fit them without having to remove the inlet manifold, if you have a silver top your PCV system will be in the way.
the Shenanigans didn’t stop there, I was getting some strange spikes in engine temps. We’ll aware this water pump is original this will very likely be the culprit. With the water pumps you can’t skimp due to it being Electic. I bought an OE pierburg pump and Meyle thermostat. Didn’t want that failing any time soon.
Looks like a turbo
under trays off to show the pump & thermostat.
only took an hour to swap over, notice the new design is plastic over alluminium
she’s looking tidy still for 150k
finally with all that lot done I could enjoy her again. Brands Hatch
so realising I was finding the cars limits in brakes and tyres it was time for some more upgrades. First up was the new PilotSport 5’s
the latest track day showed how much these tyres have really come on since the 4s. Next up I was always finding the brakes over heating after 4/5 laps. I found a relatively cheap Brembo upgrade. Brand new 4 pots and all the hardware for £700. These are from a Clio RS so easy to buy off the shelf.
fitted with Ferodo DS2500 pads. What a difference, can even use the current disc till it’s finished and you replace it with the floating E46 M3 disc.
So another track day was in order. Whooah! what a difference, bite point has come right up at one point I did 15 laps without the brakes even showing signs of heat.
There we go. All up to date
