Fantastic! Love to get down there when I've finally got my Z300S conversion done. And increased the range a bit...and added fast charging...
Steve, thanks. Yes they are. I went for oil pressure, water temp, fuel level, clock, speedo and tacho. I prefer the minimal approach. Kept std light switch and hazard switches to keep that simple. Most other switches and tell-tales were from Europa or Bowers.Dash is a big improvement, are the dials ETB?
I will stick with the baggy knicker thanks Steve. I’m also going to stick with stock hazard switch too. I feel that if the new owner (when I pop my clogs) wants to fix these they can. Taking the dash back out etc is a task I’m not sure I want to go through again.Dash is a great improvement, I have used leather and vinyl in the past but in the future, I will use leather on the seat faces and vinyl for everything else.
Shame about the fog switch as I have the same that I was intending to use for the fog and spotlights, I will have a grovel to Gookah and see if he has a solution.
The car builder solutions hazard switch is easy to wire in and looks much better than the BMW stock item. Whilst you are fitting it you can get rid of your embarrassing "rucked up knicker" syndrome!
Place a straight edge on both edges of the dash and then measure how much further back the centre of the dash is. You can then replicate this on the workbench and refit the vinyl and lose the baggy knicker look, a pain but worth doing/
Thanks TonyI like the dash too Dave, it looks spot on to me.
Mine changed the name. He just needed to see the V5C and take a copy.Can the MOT tester change it as the V5 has been changed so the database is wrong. MOT testers used to be able to change colour but not sure if this falls under thier remit.
One to ask TTony
When did he do that? Recently? So the MOT guy changed the make model from z3 to something else? What did he change it to? Did you get a new v5 from dvla?Mine changed the name. He just needed to see the V5C and take a copy.
Last MOT (October)When did he do that? Recently? So the MOT guy changed the make model from z3 to something else? What did he change it to? Did you get a new v5 from dvla?
So theres no need to send in the form V627Last MOT (October)
Yes
Yes
Tribute Z75
Yes
