Well today I took the day off primarily for a long weekend and an excuse to work on the car... the MoT for the Peugeot had just lightened my wallet by 380 quid so I needed some solace...
Thought I'd remove the front to rear brake lines, which went more straightforward than I thought !
I'd already disconnected the lines from the ASC pump last week, as it took ages for the pump to stop squeezing out fluid.
then took the precaution of marking up the left from right before removing !
such a shame that 80% of the pipes are fine... just when they enter the rear wheel arch they'd gone...
but I had always planned on replacing them with shiny kunifer anyway....
so it was a case of gently unclipping all the way from the rear, up to the ASC pump and once hanging down, giving them a wiggle to pull down from the engine bay.
I will then do what others have done and tape the new kunifer pipe to these to get the right shape...
This is the pipe and hose in the left rear..
and coming up
AN IMPORTANT SAFETY ANNOUNCEMENT !!
I decided to angle grind the hose off at the ferrule, which naturally generated a lot of heat.... whilst I was grinding off the right side and because there was still brake fluid in the hose..
THE HOSE EXPLODED...
I can laugh now but it was a huge bang, loud enough for my wife to come out to see if I was still in one piece....
luckily the ferrule shot to the ground but it could have gone anywhere.... lesson, make sure any brake pipe is empty before using a grinder or anything that produces a lot of heat....
so with that over, it was back to pulling loose seam sealer and grinding back as many areas as possible that had cracked sealer or paint..
once ground down to shiny metal in all the loose places, it was time for the Red oxide primer... if your wallet allows and you don't already have one, I can thoroughly recommend a belt file sander..... gets into all the nooks and crannies and you can swap different grades of belt
so more red oxide primer !!.... and yes I am replacing the shocks
