well today I thought I'd have a look at my dodgy outer sill and have a go at the Diff Bush..... I think I'm going to need your help again on this one...
right.. .sill first... as suspected, a previous owner decided to "glue" an end piece on with ..... body filler.... very nice..
then the inside, cleaned up a bit
getting it back to clean metal... I'd have to chop it at the line.... now it's about 1.2mm thick steel, so quite tricky to weld. Wondering if it's worth cutting my losses and getting another sill to paint ?.. don't know yet...
right.. the Diff bush.... had it in the freezer overnight.....next to the Beef Orlando.....
and this is where I ran into a problem..... first off, get your nice refurbished Diff plate...
and it was very sporting of Parkside in Lidl to supply a brass wheel which fits perfectly into the bush housing
now here comes my issue... that is not a small vice !.... it's a Woden vice with wood faced jaws. Now each time I offer the diff up, note it's perfectly square and it starts ok, looking underneath the entire ring is inside the bush opening
BUT, I get to about 2 turns in and it seizes solid, will not go in any further... i don't won't to put too much pressure on it in case the plate snaps in the vice.... anyone else successfully done this in a vice ?
In the meantime, I thought I'd adopt the Mazza Method of trolleying the subframe to the car. however, my wheel trolley is too shallow for my Jack
so, some modification is required..... enter the pallet blocks and the rivnuts !!
et... voila !!!... perfect for the Jack and I can wheel the whole thing out to the car
