Suspension advice
Eddie Zedder
Megawatt Valley, Notts.
Z3 2.0
Oh aye! Do the easy ones first eh!=))
I did the front first Tony, they were a pain in the ass, never want to do them again. :mad:
Eddie Zedder
Z3 2.0
Nice one,you didn't hang about :thumbsup:.
Did the new top mounts fit mate?.
When you doing the front ones ?.
Yes, rear mounts were the same Steve.
Done the fronts already.
Just been out for a quick spin to bed them in :whistle:, one hell of a difference, the steering wheel doesn't get snatched out of my hands on the bumpy stuff.
The passenger side front mount was shot, all the shocks were, frankly shocking and one front spring was 25mm longer than the other, i'm guessing that one was changed at some point (so much for changing them in pairs).
Surprisingly the new rear springs were 15mm shorter than the old ones but I think they are probably stiffer as the ride height is higher than before, although they need a bit more settling in first.:thumbsup: :racecar:
Bozzy
Long Eaton.
:oops:
Pleased to hear it's made an improvement after all that hard work Brian,nice work :thumbsup:.
You've put me off having a go myself though,thank god for @t-tony :whistle::D.
I think just one of my rear springs was replaced before I bought the car so like yours it sometimes doesn't sit level,sits lower on the drivers side.
Eddie Zedder
Z3 2.0
:oops:
I think just of my rear springs was replaced before I bought the car so like yours it sometimes doesn't sit level,sits lower on the drivers side.
Thanks Steve, it is a big improvement. New tyres and alignment check next, then it will be spot on.
Poprin
Telford, Shropshire
3.0 Roadster + *cough* MX5 project
So, got all my shocks the other day. Mechanic fitting them today and the last one they came to do on the back was a shock absorber for a Mercedes SLK in the box for a Z3 :mad:
Not best pleased!!
oldcarman
Canadian Zeds
Pine Falls Manitoba can.
So it didn't improve the ride quality at all?? lol. How do things like that happen? Slack quality control or ? JIM
Eddie Zedder
Z3 2.0
Not best pleased!!
I shouldn't think you were! Hope you get it sorted.
Bozzy
Long Eaton.
Had a go at fitting the new rear shocks and springs today,which turned out successful :).
New top mounts and reinforcement plates as recommended by @Dino D,thanks Dino.
The old shocks were absolutely shot,when I unbolted the top mounts,they just dropped down through the hole :rolleyes:.
The old springs were different to each other as well,perhaps why the car leant down on the near side sometimes.
The off side shock appeared to be leaking but I thought they we're gas filled,not oil ?.
Only had time for a little test ride and it felt much firmer,just seems to be making a noise driving down rutted roads,but fine over small pot holes etc.
Maybe it needs time to bed in.
Not brave enough to tackle the front struts,@t-tony :whistle::D.
No worries mate. Glad you did the hard ones first.=))=))
They're a doddle, me and @Mint breezed through Grump's ones, didn't we Dave?:)
Antm72
South Yorkshire
Nice work Steve are the anti roll bar bushes and links in good order may be a bit of your rattle.
Bozzy
Long Eaton.
It's the compressing the front springs Tony that worries me,don't like the look of them spring compressors in Halfords.
Are there some you'd recommend ?
I remember it being fairly straight forward,but then you've done hundreds of them.
2.2 Sport Individual
Haha yes Tony once we'd realised the struts were handed:whistle::whistle:
Bozzy
Long Eaton.
That's a point mate,I noticed the rear drop links look tired. I'll get some ordered.
...Only had time for a little test ride and it felt much firmer, just seems to be making a noise driving down rutted roads,but fine over small pot holes etc. Maybe it needs time to bed in.
Ohhh new suspenders on, good job Steve. Just in time for the Peaks run on Sunday.:thumbsup:
Would you like to go down that 'special locked road' again :whistle:
I think mine might be the better option Steve, whenever you have a break in your schedule.;)
Bozzy
Long Eaton.
Thanks mate,they are easy even for me.
Yes we're up for the 'locked' road again it was good fun and Grumps has swept all the big rocks away now :p=)).
:mad::mad::mad::mad::mad: ....................... ;)
