I am well happy with them mate, this is the finish that I hoped for, just hope I can achieve the same on the seats, its getting exciting nowBl**dy hell mate them are the dogs bits. You must be well pleased
I was certainly a lot happier when I started spraying them, the spec says to apply 2 coats with a sponge before spraying,Looking good Sean, much better with the spray gun then![]()
Is that to seal the leather a bit before spraying? I'll be following this with interest as our Lotus White is not White anymoreI was certainly a lot happier when I started spraying them, the spec says to apply 2 coats with a sponge before spraying,
Firstly you have to thoroughly strip the top coat with solvent and a scotch brite so that the leather becomes porous, this allows the new dye to soak in so it is not like leather paint and sat on the top, thats why the first couple of coats are wiped on apparently, I have had a few conversations with a guy called Duncan at the leather clinic and taken his advice, he said done correctly they will last for years.Is that to seal the leather a bit before spraying? I'll be following this with interest as our Lotus White is not White anymore![]()
Its very labour intensive mate, enjoyable on your own gear but it could well get a bit boring doing someone else's, for this amount of work you would have to charge around £500Looking good mate. Could this be the start to a new business venture
Yes I can see all your hard work and it's a credit to you for doing a professional job.Its very labour intensive mate, enjoyable on your own gear but it could well get a bit boring doing someone else's, for this amount of work you would have to charge around £500
In retrospect, doing one set a week from home would make a half decent wage when I retireYes I can see all your hard work and it's a credit to you for doing a professional job.
Thanks Brian, I am pleased so far, but the big test is yet to comeLooking good Sean, brt you are pleased with yourself.
Thanks Stevo, I'm sure you will have plenty of new mods next time we meetCan't wait to see your zed again next year once your interiors done going to transform your zed going to look minted mate![]()
I'm amazed how well, when you know what your doing these seats have come out mate.Managed to get some time today and get the blue base coat on the passenger seat, I won't put the clear coat and final finish on until the black is on.
To be honest I'm quite shocked how good they are beginning to look, I'm only winging mateI'm amazed how well, when you know what your doing these seats have come out mate.
