It feels completely different once the clear top coats are applied and tape sticks really well, I think most of the product has PVA in itThats how the liquid leather was a rubbery type of coating takes alittle while to fully cure but seals nicely
I tested this stuff, the over spray from the blue that was on the bolsters was really well stuck, I attacked it with a scotchbrite pad and it wore away and didn't tear at all, the final coat smelt the same as glue that I used at school, we used to call it fish glue, it was very rubbery.That makes sence some of the dying products require a bonder first they seemed rather involved , far easier ways to go about it thats for sure !
Thanks palAbsolutely brilliant Sean, it looks amazing![]()
@Mint, I think this is the problem with Pauline's seat.The passenger seat is well on its way, most of the leather paint is off but needed to remove the base cover as the bolster had collapsed and there was also some bumps in the cover,
This is the cause of the bumps, not sure what it is but its under the heater, you can clearly see what was causing the problem, easy fix with a hot gun
Yes, I think it'll be a winter job, thanks for having a look yesterday@Mint, I think this is the problem with Pauline's seat.
Thanks for the kind words Pauline @Mrs Mint, I will dye them for you but I want a life times supply of Apple CrumbleJust read through the whole of this thread Sean, amazing
Dave will sort out the problem with my seat, then we are bringing them to you to redye them lol
After all the stick you gave me on Sunday you owe me a favour or two![]()
Could you do the Spider Man effect Sean, with a big web across the seat?Thanks for the kind words Pauline @Mrs Mint, I will dye them for you but I want a life times supply of Apple Crumble![]()
Either that or I could plant a spiders egg sack in the seat, I recon Pauline would be over the moon with thatCould you do the Spider Man effect Sean, with a big web across the seat?
It's a dealThanks for the kind words Pauline @Mrs Mint, I will dye them for you but I want a life times supply of Apple Crumble![]()
'E can't even remember Key Lime Pie Pauline ...........It's a deal
But not if it's the spider effect, your soooo cruel @t-tony and @Sean d
And as for @Low Rider if you can't remember what you ateno crumble for you, see it's crumble not pie lol
Wow that looks soooo good @Sean dI'm over the bloody moon mate, like a kid at xmas
Heres a front on, the right hand bolster was collapsed, it looks nice and sharp now
