So another long day in the garage.
Took the M out for a run the other day and after about 6 miles I could feel and hear a noise from the passenger side rear...when I found a place to pull over saw smoke pouring out of the rear brake.
After I put it in reverse the brake seemed to release its self...New caliper needed..or so.I thought.!!
I've been.running bluestuff on the rear for awhile now and once warm a good pad and never managed to get them to fade....however..are they really designed for road use...
Stripped the brakes off and the pad had given up.
The piece had got stuck in the brake and was causing the problem..
So blue stuff sacked...!!
A full set of yellowstuff now on..front and rear..all brakes serviced..and all working as they should....
Note to self.....get a life...!!!
