Rear end maintenance + other bits
Today was the big day. Rear end was going in. Got a few mates round and after a bit of carry on we got it in..... Yay!
However, diff bush and diff bracket were maybe 2mm out of alignment. Not to worry, managed to get it in so the welding was pretty much in the right place.
Everything fitted and connected but 1 last issue.
The inner sleeves of the beam bushes are still too long I think.View attachment 85786 View attachment 85785 I did cut about 10mm from them but I think they need more. @Sean d
I'm thinking if I take those brackets off and try and wiggle the inner sleeve down, I can use a cutting disc and trim another 3/4mm off.
Also are the brackets on the bottom the correct way? I think they are.
Then the last issue, rear beam is fitted in place and the drive shaft doesn't reach the input coupling on the diff...1 bolt is poking through but other 3 aren't. Am I missing something here cause I can't think?
I didn't get a pic of it all fitted I was too excited.
Very very happy man.
On the prop shaft Davy, is it possible that the sliding section of the shaft is seized due to being stood too long? I really can't see what else could "shorten" the shaft mate, if it is that some release oil and a knocking stick should sort it.
Davyhoogy
Sunderland
'98 2.8 z3
I was thinking it must be able to pull back and forth. I can't remember if it did, which part?
Sean d
Lincolnshire
I'm sure I asked ya and you said yours didn't come with a washer lol. So it's all got to come back out again
After seeing yours with washers I rang Duraflex and they posted a set out to me, he said washer at the top but yours alrady looks to have one
Sean d
Lincolnshire
Mine needed top washers as the post at the top was very narrow but yours looks ok as it comes to the edge of the bush
Hi mate it slides at the centre bearing assembly going by this from Real Oem.
Hope this helps mate. I bet the splines are stuck.
Davyhoogy
Sunderland
'98 2.8 z3
Ah right I see. I emailed them but didn't get a reply a while ago.
Do you have a pic of yours where you can see them at the correct height? I still need to trim a bit off the sleeve as the bracket on the bottom isn't high enough for the Allen bolts to go in
Sean d
Lincolnshire
I don't have a pic but really had to compress the bush to get the right height for the bracket to locate
Davyhoogy
Sunderland
'98 2.8 z3
Let me try my best here, bear with me lol.
@Sean d
Right so the mounting pins have a hex nut shape at the top of the pin...
In this pic the bush, as it is right now, has been pushed up as much as it will go and is sat flush with the top of the mount with no gap....
If I put that washer on the top, it would only go up to the hex bit and stop there, so there would be a gap where I drew that red line.
Sean d
Lincolnshire
@Sean d
Right so the mounting pins have a hex nut shape at the top of the pin...View attachment 85866
In this pic the bush, as it is right now, has been pushed up as much as it will go and is sat flush with the top of the mount with no gap....View attachment 85865
@t-tony what do you think
Sean d
Lincolnshire
It might be the camera angle but the locating bolt in the second pic looks a bit bent to one side
Davyhoogy
Sunderland
'98 2.8 z3
It's a very zoomed in pic but it does a bit. It possibly was as my road is unlevel and lowering off the pins sometimes the frame twists as you probably experienced it can be a bit tricky. I've never noticed just by looking at it though.
roadvoyager1
Shotley Bridge
2.8ltr
Been 10 months since I did mine but as I recall the hex nut and washer should be tight against the chassis member. Yours has 15mm or so of plain shaft visible. Unfortunatrly didn't take any photos and relying on my memory so could be wrong.
Davyhoogy
Sunderland
'98 2.8 z3
So after some digging it appears the washer does go at the top, flush with that hex and that there will be a gap above.
Apparently ASC did kits with washers that packed this gap to prevent and further movement... see below
Davyhoogy
Sunderland
'98 2.8 z3
FINISHED. (Apart from a rear heat shield, some interior trim and a bit of paint).
First very gentle (mot-less) drive around the block, All seems ok. Didn't blow up or have z brake failure.
Davyhoogy
Sunderland
'98 2.8 z3
Feels good, don't it. I remember how it felt getting mine back together after doing the back end. Just a matter of getting used to the new noises.
Someone was cutting concrete in the next street, I was like "s**t is that my brakes binding"? Haha. Very on edge.
I can't wait to get on a motorway at 56mph and get some easy miles on it.
Z3I
Weybridge, Surrey
Fiji green 2.8
That first drive after so much work! Talk about nerves! Well done.
Sean d
Lincolnshire
Faheem
Leicester
Well done mate. I bet you must be relieved that it all worked after you put it back together =)) i know i was!
Mine is in for an MOT tomorrow or Wednesday. Sadly I wont be taking it there so I won't get to see the look on the MOT testers face :whistle:
