Following on from the 2.8s demise on the Nordschleife it's only fitting to carry on the engine swap thread here.
So I'm going to attempt and get the car ready for Vanity but it might be difficult as I have an offshore trip in the middle.
Last saturday went extremely well considering the 34* heat me and Gaz had to work in, we also shocked ourselves in removing the gearbox and engine in 3 1/2 Hours flat, that even included stripping the engine bits.
Hook up
Take the weight
Gentle Tug
Exhaust manifolds removed with the nugga nugga
Vowalla a stripped M52TU
Also while I was on the ring the gearbox seal decided to let go and start dripping, typical aye!
So the plan now is to fit an M54 3.0 lump, if none of you are aware the TU and M54 lumps are virtually identical. To speed up the swap I'm going to use all the 2.8 gear including inlet manifold and engine loom and just run the 3.0 lump on the current mapping. In theory the only thing that should of changed is the stroke. Also this 3.0 lump has just been built and the bloke is taking the 2.8 lump in exchange, he likes to turbo the TU units. This 3.0 is also ready to take a turbo at a later date so watch this space.
My garage looks like a scene out of scrap heap challenge
