Pingu's M Roadster
-----------Summer 2017----------------
Crankcase ventilation hoses - £31.74
Aluminium (for intake cooling & shielding) - £21.58
Loft insulation (for intake cooling) - £0
(I've tested it - and I can't set it on fire!!!)
Stainless steel mesh to keep loft insulation in place around MAF-to-Plenum elbow - £4.99
Gold heat tape (for intake cooling) - £19.58
(I can't set the gold tape on fire, either!!)
-----------Winter 2017/2018-----------
Exhaust modifications...
Made straight through muffler using 304 Stainless Steel
Rear exhaust section with a bypass valve fitted...
and fitted to the car...
Total cost for the stainless steel tubing, argon gas and stainless welding wire was around £100.
Bypass valve and switch was around £35.
Oil & Filter Change - £50
Antifreeze Replaced - £30
Auxiliary Belt Tensioner - £22
Idler Pulley - £10
Guide Pulley - £12
2x Copper Nuts for Exhaust Manifold - £12
Rocker Cover Gasket - £13
OEM Air Filter - £6
Simota Air Filter + Cleaning Kit - £45 (Rolling Road proved that it is a waste of money)
Water Pump - £28
-----------Summer 2018----------------
Hose for Emissions Pump - £4
Lots of time spent on 3D printing new MAF screen (https://zroadster.org/threads/maf-screens-removal.24222/) - £10
Still to do (with estimated prices)...
Replace oil cooler o-rings - £5
Connect tweeters and rear speakers - £0
Investigate connecting plug to the back of the radio - £0
---Thread
Clean and paint front suspension components - £0
Fit Randy Forbes rear floor strengthening - £410 (already bought)
Preventative or is the floor on it way out?
It was to future proof it, but I don't think that it's needed. I welded my floor back when I first got the car (2010) and it hasn't failed since.
I seam-welded across the joints between the boot and the floor, rather than the limited number of spot welds that BMW applied :)
I agree with the guy from Yorkshire that we both know ;), that just chucking lots of metal at the problem isn't the best solution:). That's why it's been on my garage floor gathering dust for the past five years:wideyed:.
That's an impressive list of jobs Pingu. Whats the exhaust valve do? Open up that branch of the exhaust? How is the noise?
I didn't know you had contributed to the Forbes retirement fund :rolleyes: Think your fix should be ok so its a big job to fit for maybe no gain?
He uses it to scare old ladies......
Holy s***, theres some over kill, saying that if you are tracking your car regularly it may well do the trick
Yep, this is on an ///M that is a track car.
Yes, it works as a town-friendly car with the valve closed and as a monster with the valve open. It's perfectly safe because there is a cross-over pipe.
The comment from some bikes that I passed was "By 'eck, that's jolly loud. old boy", or something like that - I couldn't hear them properly:whistle:
:banghead:
I spotted this on Facebook the other day, another solution I have not seen before
b9a56c43-d7ea-471c-81b8-aba65f877718-png.86879
161e4704-8c5a-4b96-9b24-aa7da14f9ac0-png.86880
I'd consider this as a strut brace, but without the trestle. The downside is the added weight. I'd probably use an aluminium strut. I think that it could be hidden quite easily. The solution that I had in mind is not as good as it would infringe the hood space.
I'd need to measure the twist in the car to see whether ANYTHING is required and WHERE to spend my effort before I do anything, though.
I'm starting to think that brake mods are what I will need soon:wideyed:.
-----------Winter 2018/2019-----------
Modified air filter box with improved flow rate.
Flow rate was improved from 444cfm @ 28” H2O to 485cfm @ 28” H2O....
-----------Summer 2019----------------
Inspection 1 (12/08/2019) [137,996 miles]
- Oil Filter - £20.17
- Mobil 1 - £30
Brake fluid changed - £10
Coolant changed - £30
Valves Checked...
Original valve shims...
New valve shims...
Tyres and brakes checked and measured...
Reactions: Lee
After driving 61 miles in 1000 days, Bluey is MOT'd.
Photos have been sent to the insurer for the guaranteed value to be confirmed, and then it will be taxed on 1st May, ready for it's next adventure.
Is it coming up to Argyll?
That's the plan. After 60 miles in nearly three years, what could possibly go wrong? =))
Well it's managed 60 miles so better than someone we know =))
