Pingu's M Roadster
I made it half way round until the indicators and brake lights gave up the ghost...
The indicator was found to be one side of the hazard relay was shorting out.
I had to replace the hazard relay, which wasn't cheap, but Schmiedmann were the best source of an OEM one...
BMW Part Number = 61 36 1 388 533
[edit] Plus 29p customs tax - and £6.65 FedEx admin fee :eek:
Things to do over winter...
Inspection2 Service
Rear end refresh
Clean and patch paint small areas of corrosion
Paint rear beam
Repair jacking points
LHR brake pipe - replace copper with Kunifer
Replace handbrake cables
Rear beam bushes
Rear arm bushes
Overhaul differential
Replace diff mounting bolts
Paint rear arms
Remove broken exhaust hanger bolt in rear beam
Clean and paint rear calipers and mounts
I've cleaned the rust off the diff, and the handbrake cable has arrived.
I'd done the diff before, but it was very rusty and lots flaked off. I'm waiting for the day when it becomes porous :eek: - that will be a very bad day.
I used Jenolite to try to neutralise the rust, but I'm going to give this stuff a try...
Now the sun's out, I can crack on...
Rear beam and diff painted with epoxy paint, and fitted.
I hope to remember to fill the diff with oil :oops: .
Break-away torque was more than 60Nm, but less than 70Nm, so the clutches are good.
The backlash was 0.0025", so that's good.
New bushes. I used poly, as they are very easy to fit. I burned the old ones out. I reused three of the "bolts of death", but one had become an 8mm hex instead of a 6mm hex, so that's now a hex-headed screw and washer. I had to use my butchery skills to carefully remove the remains of one of the exhaust hanger bolts on the beam, but success.
I've replaced the handbrake cables.
Next is the rear arms and driveshafts. I've cleaned one, and hope to clean the other tomorrow. Then paint and fit them.
I'm just giving it a limited Inspection 2 service before a small jaunt on 6th of June (D-dAAAy).
I've called it a limited Inspection 2 as I won't be checking the valve shims. They were last checked on 16/02/2022. The car has only done 4000 miles since then.
Diff oil changed
Engine oil changed
Oil filter changed
Spark plugs replaced
Air filter checked. Cleaned, but not replaced
Coolant replaced
Brake fluid replace
Brakes and clutch bled
I use the appropriate checklist...
