Can do mate, no problem. I think it's worth a try with some "regular" pads if only to compare. If those discs are warping you need to contact the supplier Steve, they must be guaranteed?
Thanks Tony,yes there is a warranty with them but I didn't print off the on line receiptCan do mate, no problem. I think it's worth a try with some "regular" pads if only to compare. If those discs are warping you need to contact the supplier Steve, they must be guaranteed?
To be fair they only make that noise after really caning it when out on my own,they don't do it under normal driving conditions.Mate, those are quality discs and don't warp easily, it has to be down to the extra braking you are having to do, if your pads a popping and crackling when you get out of the car they must be knackered.
Sounds like they are not gripping the disc and causing a massive amount of friction which is causing the heat.
Thanks Brian,I didn't know that could happen. Every day's a school day.The juddering can be brake pad transfer, i.e. Bits of your pads attached to the disc, I get this sometimes at the start of a track day, it soon wears off.
IMO no mateWould new brake fluid have any impact on the juddering ?
Steve
Steve
Thats true Tony, I have to stand on mine when they're cold but the pay off is worth it when they warm upIf they needed any special preparation it would have told you on the packaging I would have thought Steve, my guess is you have to be fairly brutal with them to get them to "bite" for a start. Roy said his need some warm up every time he uses his car too. It's very unlikely that you will have fitted them incorrectly mate. Have you looked on their website for "bed in " info?
Thanks Niall,I took it easy on them for a few hundred miles,then did the progressive braking runs and all that and kept biding my time with them but after a few thousand miles you'd think they'd be up to optimum working condition.Dont panic I fitted black diamond disks and red stuff pads on my old girl, took forever to bed in but when they doGo steady with them for a few hundred miles.
Crikey that's a scary pictureBit more info here, it gets a bit involved but would be surprised at a warped disc.
http://www.stoptech.com/technical-support/technical-white-papers/-warped-brake-disc-and-other-myths
Hope you did not get them this hot!!!! This is what happens when you do not bed brakes in properly...
The front calipers are fairly new Lee and the back ones were well cleaned and sliders lubed when I took them off for painting,but when I put the new pads in they were quite tight to fit in as they seemed very thick so the pistons were pushed right back in.I doubt it is the disc warping, more like a calliper grabbing, Sticking piston or sliders.
Could that cause problems ?.
Steve
Most definitely not mate. Fluid can't cause juddering but juddering can cause aeration of fluid due to piston being moved back and forth very quickly (juddering), which can give a slightly spongy pedal.they weren't cheap at £360
Oh yeh definitely, sorry mate thought you had just fitted them, mine took about 200 to get to optimum, if they still aren't any good after a few thousand some issue somewhere, doubt its the disks though more likely the pads IMOThanks Niall,I took it easy on them for a few hundred miles,then did the progressive braking runs and all that and kept biding my time with them but after a few thousand miles you'd think they'd be up to optimum working condition.
Steve
......pleasey
