Build up pictures
oldcarman
Canadian Zeds
Pine Falls Manitoba can.
I guess a Z3 roof with a glass window would be ideal but it's how the roof folds and into what space that limits the possibilities.
The 68 mustang had a split glass rear window which worked great and folded perfectly and I'm sure with a bit of experimentation could be made to work in a Zed.
Sir Percival
Redditch
It was me that had one done in Swansea, £300 fully made up and fitted. He actually said that people doing these conversions have asked for different style roofs with extra windows and different designs which I'm sure he said he has made up for them. He makes them himself and will do pretty anything from what he was saying. He was actually explaining to me that he wants to make a Z3 roof with a glass window but has yet to find a way.
The guy at Croydon is also excellent, I've now used both and not been disappointed with either.
Spoke to the chap at Croydon....very helpful....I think I will use them....mainly because he asked me to send pictures and diagrams of what I would like...when I spoke to Jack at Swansea it was more a case of "call in to discuss"....which is fine if you are local....Estimated price at Croydon was reasonable too...thanks for the help guys :)
Sir Percival
Redditch
So started trying to undo the nuts at the bottom of the near side shocker....man they were tight, couldn't budge them, even using my extending wheel brace.
So I thought I would apply some heat with a small gas gun I've got....then I had second thoughts, didn't really want naked flames in my garage....so I used my hot air gun, put it on max and heated the bolts for about five minutes, snickety snick they all cracked off.
No flames, no chance of setting the garage (or my trousers) on fire, great solution.
Sir Percival
Redditch
Right that's it. Both front lowering springs fitted, and the struts back in the car.
If the first one was a pig, the second was only a piglet.
Glad they are done though
Drilling holes for the front indicators tomorrow.
Sir Percival
Redditch
Thanks Andy....it's a genuine early 60's flat colour....all the old colours are available but most have metallic or pearl mixed in now. I watched an episode of Father Brown the other day and they had a beautiful car, an old soft top Riley I think, and it was beautifully painted....but in metallic candy red.....looked great....but just so wrong.:(
I think that colour makes this type of car very classy.
oldcarman
Canadian Zeds
I agree with @ Andy McDonnell metallic paints do not belong on that style of car, I think it screams reproduction with candies and pearls, etc! JIM
Sir Percival
Redditch
OK cut the holes for both front indicators and fitted them.
First picture shows it taped up and a cardboard template inserted to get the middle for drilling
Second shows the hole cut
Third shows lens fitted with tape still in place
Final with tape removed
Both dead central. Used a tapered hole boring tool, hardly any dust, just shavings and no paint damage at all.
Sir Percival
Redditch
OK both headlights installed, wired and working.
Also left hand side repeater indicator drilled and fitted, Got a nice hole with no paint damage and a nice snug fit, in fact so snug I greased it up with a bit of washing up liquid to get it in.
However, they are quite long, so I slid a nice tight fitting plastic washer over the back of it before holding it in place with a tie-wrap.
Wired it all up....bingo....all working.
Will try and get the other side finished by next weekend....worst job will be making sure both repeaters are in exactly the same place...other than that fairly straightforward.
Will take some pictures soon...but they currently don't come out too well because the car is nose-in, in the garage....which means the flash fires and you get a lot of reflection, and this makes the car look far darker than it is.
Paul Rice
Doncaster
Z4 2.5 E89 23
Cars looking good. Really looking forward to pictures of the completed car.
Sir Percival
Redditch
Did a few prep jobs this week, wipers nearly finished, washers checked and prepped (had lost the windscreen washer pipe in amongst the bodywork....so operated the washer, looked where the water was coming from, and there it was)
First back light assembled, holes "modified" a little, and it's now ready to fit.
I will probably leave this now though because at the moment the front end is up on stands. Getting tyres fitted to the wire wheels next week so will be able to fit the front ones, drop the front off the stands and get the back on stands instead, so I can change out the rear springs. Having it up with the back wheels removed will make wiring the back lights easier.
I kept the rear light back plate bulb holders, so hoping to wire directly into the back plates, then the plug can stay operational and the back plates will be able to go back on and cover the old Z3 rear light holes and hide all the wiring....all nice and neat in the boot then.
Intend to try and tidy up all the front wiring (split convoluted tube is a wonderful thing) then fit the front grill chrome surround, and the front grill itself and maybe the bumper and spots. Will also try and finalise the wipers and washers....sounds perfectly feasible but sometimes things just take longer than you think....so fingers crossed.
Hope it all goes well here on in.:)
