BMW Z3 Wheel spacers
Z
zedonist
Guest
So that will be ping from your clubs and ping from your bolts:whistle:
oldcarman
Canadian Zeds
Pine Falls Manitoba can.
1.9 M44
She's Scottish too Jim remember. Gifts would be minimal and infrequent.
My Mom's maiden name is MacDonald and at my age minimal and infrequent fits perfectly. Once a king always a king but once a knight is never enough. Or I may not be as good as I once was but I'm as good once as I ever was!! Dependant upon which pills I take. Jim
oldcarman
Canadian Zeds
1.9 M44
Haha, yes, as long as the wheel doesn't run out more yards than my driver I'll be alright with it.
Did you read my post about how far my loose wheel went and straight as an arrow before my natural hook took over, but I never lost sight of it and found it easily in the rough. JIM
Grumps
Forest Town, Mansfield
Z4 e85 2.5i
Hi Davejue1, if you could take a few pics it would be appreciated. reading up on it, it seems easy but pics would help. Thanks.
Will do no probs.
Lexybhoy
Glasgow
Sounds delicious, can't wait for my chance to try one on! JIM
All this deep fried stuff sounds worth trying, however I've yet to find somewhere that actually sells it. I've heard you can ask for it some may oblige but not many.
I think I saw on the news somewhere in Hamilton were doing deep fried creme eggs this weekend !!
So back to topic. Lowering springs and shock fitted midweek, adjusted the spring to its lowest with the nut still in place. I think it's sitting about right.
So the following pic is with standard suspension and no spacer.
And the next pic is the o/s with lowering kit and 20mm spacer.
I think I could've went for 25mm easily !
Maybe I'll buy another 5mm set and just add them on and bluetac some bolts on. :p
Of course the o/s will sit better once I do the n/s and then onto the front suspension. I will not be putting spacers on there tho, don't think it needs it.
Grumps
Z4 e85 2.5i
I was asked while fitting the spacers if I'd take some pics so here you go.
Before:
Sand or wire brush the hub and slot the spacer on. This shouldn't need anymore than placing on. Don't start hitting it. If it doesn't slot on easily it's the wrong fitment:
Finished article:
And finally a bit of porn for Gaz!
Really pleased with the results. The wheels are 18"x8.5j with an et of 47 and I've fitted 20mm spacers which has bought the wheels bang in line with the arches. :)
Grumps
Z4 e85 2.5i
That looks loads better Lex. :thumbsup:
Excellent job Dave. Looks great.:)
Dino D
Kent
2.8 Manual
Started new post instead if derailing this one!
Great job Dave, they look a lot better.:)
Lexybhoy
Glasgow
Thanks Dave. Yours look spot on. I think I should have gone for 25mm ones. Yours seem to sit just that bit more in line with the arch. Mines are just short of it.
However, I've just fitted the remaing 3 corners of the coil overs and low and behold the front wheels are fouling on the adjuster nuts.
So what I think I might do is get a new pair of 25mm spacers for the back and see if the 20mm ones I just bought will look acceptable on the front. I suspect they may stick out too much and possibly the tyre may fowl on the arch. If that ends up being the case, I will turn them down to 10mm on the lathe.
