Well you need an earth, the fibreglass isn't very conductive.Am I being thick? Why do you need an earth to be one of the seven? I would expect you to need side lights supply wires, though.
Thanks, yes I came to the same conclusion and have ordered a 3 core, hope I can get it down the trunking.A secondary cable (3 core) would sort you out and need another connector ?
If I did mine again I would have introduced some form of connection at the hinge end of the bonnet
If you haven't done the rear I have drawn up some of that detail too. It does think the car is a 2001 but I bet not much of the BMW wiring colours varied a great deal over the model years.
Good point. I forgot that your lights are at the end of the bonnet, and the wire has to go the length of the bonnet back around the hinge.
I was right - I was being thick.
Yep, triumph heraldTriumph gearbox?
Thanks, will give it a go. Got some time before there's any danger of it getting dirty though.Looking good. Well worth giving the under bonnet a coat of flow coat, stops all the dirt and road debris sticking to the rough GRP, needs to be done before it gets dirty.
I doubt if anyone will ever check!And now it's down the rear lights are definitely not 250mm from the floor![]()
Merry ChristmasI doubt if anyone will ever check!
Have a great Xmas
She is back on her wheels so that I can get the headlights sorted. Handy tip: make sure that the handbrake is on when you lower the car - I've just run myself over with it.View attachment 286205
