Well you need an earth, the fibreglass isn't very conductive.Am I being thick? Why do you need an earth to be one of the seven? I would expect you to need side lights supply wires, though.
Thanks, yes I came to the same conclusion and have ordered a 3 core, hope I can get it down the trunking.A secondary cable (3 core) would sort you out and need another connector ?
If I did mine again I would have introduced some form of connection at the hinge end of the bonnet
If you haven't done the rear I have drawn up some of that detail too. It does think the car is a 2001 but I bet not much of the BMW wiring colours varied a great deal over the model years.
Good point. I forgot that your lights are at the end of the bonnet, and the wire has to go the length of the bonnet back around the hinge.Well you need an earth, the fibreglass isn't very conductive.
I was right - I was being thick.
Yep, triumph heraldTriumph gearbox?
Thanks, will give it a go. Got some time before there's any danger of it getting dirty though.Looking good. Well worth giving the under bonnet a coat of flow coat, stops all the dirt and road debris sticking to the rough GRP, needs to be done before it gets dirty.
Good call regarding flow coat Steve. I did mine and glad that I did. Mine is grey so it helps a little bit with the light under the bonnet if I ever lift it up.Looking good. Well worth giving the under bonnet a coat of flow coat, stops all the dirt and road debris sticking to the rough GRP, needs to be done before it gets dirty.
I doubt if anyone will ever check!And now it's down the rear lights are definitely not 250mm from the floor![]()
Merry ChristmasI doubt if anyone will ever check!
Have a great Xmas
Coming along nicely there Piran. Well doneShe is back on her wheels so that I can get the headlights sorted. Handy tip: make sure that the handbrake is on when you lower the car - I've just run myself over with it.View attachment 286205
