And so it begins again
Then got the slam panel in primer, also stripped the power steering coolor whilst I was at it
Any plans to take it to show it's former owner that you've bought it back to life @Sean d
I will be painting the slam panel Austin yellow but as for the rest, it has been done neutral as has the underside and under the wheel arches so if I decide to change the colour in the future it will be a lot easier ;)
Bloody hell @Sean d, you haven't even put it back together and you're talking about a colour change. It's not fair.
You can't put us all through that again. You kept us waiting long enough for this one. =))=))=))=))
Its only a just in case pal and will be a number of years:D, I also like the idea of the engine bay in satin grey, it looks very OEM, oh and there will be some Austin in there as well as the slam panel ;)
Just how hard is it to paint under the bonnet/engine bay Sean? Do you have to use a very small spray gun? Masking must be a pain too.
It is quite painful mate but I will be removing as many ancillaries as I can, yes I will be using a mini gun and put it on squirt rather then fan for the more awkward areas,
I should've sent you a can of "Scrubbing Bubbles" mate. By the way those wheel bolts should land very soon Sean.
Actually I do need a recommendation on what to use as a general engine cleaner as I want to give it a thorough clean before I paint it
You have mine mate.;)
I use Autoglym machine cleaner mate, seems to work well. Squirt and scrub then hose down with a very low pressure trickle, pat the worst out then a liberal spray of Autoglym Vinyl spray, all over, leave for a couple of hours then buff up.
