Cycling home on that would see me pull up on the drive as i have to push off a gain
Hey what's going on here
????.Did you not know Steve .Hey what's going on here????.
But but but eh ?Did you not know Steve .
In your absence your zed has been nominated as zedshed pool car![]()
Yeah, it has a set of teeth on it that lock automatically as it rises. Bit like a clock mechanism, probably has a real name but I don't know what that is! Nice and safe whilst underneath. Have a slight concern about the weight loss from the rear when we take out the sub frames, but will be looking in to an adjustable prop to go under the engine when it's in the air.Does that lock into position Gaz. Don't trust it if it relies solely on pressure to keep it up.
That's our thoughts although unlikely, but to be honest we do take safety seriously when we are tinkering! We've only had 2 cars up in the air so far, and will likely relax a little once we have a bit more experience with it.What do you mean by weight loss? Does the front go heavy ? It's just because you are effectively moving the centre of gravity of the vehicle when you remove some weight off the back.
A couple of long 6x2 planks will aid in getting low cars on it, run them parallel to the lift and drive on to the planks. Nice bit of kit, ever so slightly enviousSo.... this arrived in the 'shed during the week... In the best Rolf Harris impersonation, can you guess what it... Oh, hang... probably best not to go there
It basically does this!
Actually can lift the car much higher than this, but our small compressor is struggling a little. Bigger compressor now on the shopping list... To be honest, we really struggled to get @Rally's Z4 on it because it's so low, but with a guy on each corner lifting we got there!
The stats of the little beastie.
Nice sturdy piece of kit.
With Rally's car we probably only needed another 15mm or so, so thinking some scaffold planks should do it.A couple of long 6x2 planks will aid in getting low cars on it, run them parallel to the lift and drive on to the planks. Nice bit of kit, ever so slightly envious![]()
When can I drop mine in mate?![]()
