Ok thanks for the advice I've got a multimeter that works how difficult is to track down a circuit diagram
. Do BMW publish them at all..
Was thinking of a replacement indicator stalk. Good schematic of the lower cover presume the steering column goes down to remove the upper cover..What is it on ebay you are trying to buy for £25?
This might help with removing the trim
https://www.newtis.info/tisv2/a/en/...wheel-alignment/32-31-steering-column/Fdguo6G
I found this, so looks like you might be right removing the steering wheel (it is not a big deal, scary but do it right, nothing will go wrong)Just like to thank you all for your efforts on my behalf. Am happy to have a go at getting the stalk out though the sites I've seen say remove the steering wheel and whilst I've got the tools I'd be a bit nervous about the airbag, even with the battery disconnected. If anybody's done the indicator stalk without removing the wheel it would be good to know.
I'm still not sure how to test it without a circuit diagram unless I bought a replacement, there's one on eBay for £25.00, new they're nearly £70.00, and just swapped it out. Could always sell it if it didn't change anything.
Thoughts..??
Not sure if changing the battery could be a factor? When I changed the battery last year in our Z4 everything seemed to be OK except for the air con. After searching I found out that when the battery is removed the car goes into transit mode; i.e. it basically shuts down and in our case the air con didn't "wake up" when the new battery was fitted. Luckily it only cost me £40 to get it diagnosed and sorted.Seeking some advice on what could be causing the OBC to not show any information when depressing the stalk. The display seems to be working fine as the clock, service indication all seem Fine and when I first drove it did display the range of miles but Wouldn't switch to show other features. I did change the battery but since then even the range indication no longer shows..I have had the binnacle out but nothing obvious and ideally want to avoid having to send that away if possible
I have used a local Bosch Service centre for over 12 years and their diagnostic equipment was able to clear the battery fault code and that sorted the air con.Hi zed carer thanks for the info, how did you get the aircon reawakened was it a dealership issue?
