MarkG
- Joined
- Aug 15, 2019
- Points
- 28
- Model of Z
- E85 3.0se auto
Hi guys, after some help please!
I’m aware of numerous issues with E85 roofs but this has just happened and as I’m a fairly useless mechanic except for basics, I’m hoping there’s someone local to me (Chesterfield, Derbyshire) that might be able to sort it without ripping me off.
I’ve had my z4 3.0 (2004 / Auto / 72k) for around a year and the motor has worked fine until today. I heard the sound of fluid sloshing around to my right as I opened the hood, and could see some located in the recess below the mechanism. I managed to raise it again and then it pretty much stopped moving. It’s looking like it’s dumped all the hydraulic fluid out somehow. The motor has previously been relocated to avoid the water issues and is still working electrically. Fortunately I’ve been able to use the release tab and manually raise and lower with the electronics still locking it in either open or closed position, so I’m pretty sure it’s just something like a failed hose or fitting of some sort on the hydraulics, but in no way do I fancy trying to remove the hood to locate the offending part. Help & advice much appreciate!!
Thanks in advance!!
Thanks in advance!!
