Z3's gone to Hospital
s*** sorry to hear that, what's the plan mate?
He’s going to throw a BBQ and we’re all going round with our spanner’s to fix it :)
Sounds a plan Brian. :). I'll bring the sticky tape to patch it up! :D
Love the car to bits and lots of offers of help, Having a week away in the lakes with the Z4, on my return leaning towards getting the car fixed and sold on or not. Need to take the top end off and re assess so thats the next step. Sod the money its my baby and needs the respect it deserves to save it.
Well put it off long enough, tomorrow the investigation on the Z3 begins. Taking the top off including head if needed, still hanging on to hope the problem may be nearer the top than the bottom. Will update with pictures, if i don't get too emotional during the operation.
Good luck pal,
Expect the worst and hope for the best Paul. Fingers crossed that nothing is seriously bent or broken in there and Tony’s diagnosis is spot on.
Paul,
Try not to worry too much (easy for me to say when its not mine:nailbiting:).
There are not many things that kill an engine permanently. A thorough investigation, some TLC, a few pennies and she will be running around like new(ish). There is a BMW truckload of expertise in the list of ZRoadsters above to bring her back. All the best.
CW
Best of luck mate, I feel for you as I'm in a similar place with my black zed. I did a head gasket change and top end rebuild and thought everything was ok. The car ran great for about 500 miles then it started miss firing. The problem I have is cylinder 5 keeps oiling up. If I clean the plug the car runs great for a while then fouls again. I did a spark plug shuffle and again, it runs great then number 5 oils up again.
I'm suspecting piston rings or the nikosil coating on the cylinder walls. If it's the nikosil coating, then the engine is f****d.
I'm not sure what I'm going to do next. I might sell it on as a project, might fit another engine or might break it for spares. I've spent a few quid on it over the last 12 months but I've done everything myself so haven't had to pay anyone other than for reconditioning my cylinder head.
If your problem is the head gasket it's a relatively easy fix, it's not too expensive and not a difficult job if you can do it yourself. Good luck.
Finally got round too and started today. Well i helped!
New tool box on display, Got to look the part even if the talent is limited
The strip down started
Was half hoping something was wrong up here but everything looks exactly as it should
"Have you nearly finished, i want my walk"
Well gone as far as we can today need a lock for the cams (be here next week) Manifold off along with lots of other bits just thermostat and front pipe to disconnect before removing the head. Only anomaly so far the valve stem on cylinder four on the right bank looks blackened. Cannot view left bank yet till its off. All valve stems seem solid and straight, at least the ones we can see.
Good luck with the search. Hope it sticks out when you find out what's wrong.
What about a short block rebore & new pistons
