So this is just a small update, no major progress the adapter boards for the bms are all finished, the updated main board is all in and working with no major issues, I've worked out how I'm going to run the HV cables under the car to the rear battery also noted some cracks around the spotwelds in the boot where the rear diff mounting fixes
I've seen some horror stories over this but mine was very minor so jacked it up from underneath and re-welded
where my new battery pack is going to go in the boot the existing battery is going to be in the way, well not in the way as such but it will be totally inaccesible so I have to relocate and since their is no room I'm fitting a motorbike battery which is a quater of the size
I just need to make up some proper mountings now
