Probably 60-70 milesOur house battery is 14kWh, and our house uses 10kwH per day.
It really puts the automotive battery capacity issues into perspective.
What range will that give you?
I wish I knew you were doing that, I would have bought your cutout and installed it with a couple of exhaust tips on the other side of my Z, to discourage rev heads from taking me on...just got the laquer to do tomorrow and that's another job off my list (doesn't seem to get shorter)
. But now you have ruined it by filling it up with fiberglass and putty, you did a great job of it BTW , but now It,s worthless to me...yes I was aware of the range limitation most production electrics have 50Kwh plus packs completly redesigning, using all available space and swapping to the lexus drivetrain which I believe @Tom Cheesewright is going to use in his next build I believe I could fit in around 44Kwh but the battery pack alone would weigh in excess of 300Kg which would have a detrimental effect on performance, range and handling it's all a big juggling act and as I rarely do more than 12-15 miles in one trip this particular compromise suits meBugger me. Did you realise it would be so little when you started the project? I would enjoy overcoming the technical challenges, but would be very disheartened by the range - unless it is 70 track miles and you can trailer it to the track. Then it would be big smile time.
Same. I drive my kids to their clubs and do the occasional shop in this car. Rarely more than 15 miles in a day.yes I was aware of the range limitation most production electrics have 50Kw plus packs completly redesigning, using all available space and swapping to the lexus drivetrain which I believe @Tom Cheesewright is going to use in his next build I believe I could fit in around 44Kw but the battery pack alone would weigh in excess of 300Kg which would have a detrimental effect on performance, range and handling it's all a big juggling act and as I rarely do more than 12-15 miles in one trip this particular compromise suits me
Have you got the 1.5 or 2kwh modules in your pack ?Same. I drive my kids to their clubs and do the occasional shop in this car. Rarely more than 15 miles in a day.
With a second pack I'll have about 50 mile range and with fast charging, that's absolutely loads.
Nonetheless, for the next one I'm targeting 36kwh and enough range to get from my house in Manchester to my folks in the Midlands. Or across the Pennines to see fellow EV nerds. I think that's about as much as you can put in a Z3 without ruining the dynamics, or making it unsafe, based on current battery tech.
1.5 in the first car. 2kwh going in the second one.Have you got the 1.5 or 2kw modules in your pack ?
It should only take me one more day to finish getting my 20Kwh pack finished then I can start some testing just need one day of good weather to get under the car to run the cables cant wait to dome some range and performance testing done1.5 in the first car. 2kwh going in the second one.
So that one good day I needed turned into a weekIt should only take me one more day to finish getting my 20Kw pack finished then I can start some testing just need one day of good weather to get under the car to run the cables cant wait to dome some range and performance testing done![]()
Not sure I'm actually going to sell it yet but I've got my eye on an audi tt thats calling to me and just don't have the space oh and it would be another ev conversionYour market is likely to be very limited. There must be specialist/enthusiasts out there somewhere though. Maybe you could contact Classic Car weekly or like and see if they were interested in doing an article? Good luck with selling!![]()
330v for bothWhat sort of voltages are present on the Hv side and what is the output voltage from the inverter ?
